R34 gtt tiptronic transmision upgrade parts/kits tricks
Hi can any 1 help ?point me in right direction?
i have a r34 gtt tiptronic that is in need of a stronger transmission to handle more boost does any1 know of any kits or upgrade parts to make it stronger must stay a auto as I'm a paraplegic (wheelchair user) and can only drive on a automatic license the transmission is totally stock and has started to slip any information or help be massively appreciated thanks Ryan??
  • 1 month later...
R34 gtt tiptronic transmision upgrade parts/kits tricks Hi can any 1 help ?point me in right direction?
i have a r34 gtt tiptronic that is in need of a stronger transmission to handle more boost does any1 know of any kits or upgrade parts to make it stronger must stay a auto as I'm a paraplegic (wheelchair user) and can only drive on a automatic license the transmission is totally stock and has started to slip any information or help be massively appreciated thanks Ryan[emoji1303]
  • Like 2
If the above is your car, then my auto is taking a BW EFR quite nicely.
It also looks like those are UK (?) plates, which would make shipping astronomical, I'd wager!
If there's no local knowledge on the gearbox (and there really isn't here either tbh, I got really lucky) it would almost be worth calling around your local performance/drag racing shop and seeing what they can do or whether they are receptive to it.
There's TCU's around for sale that drive auto gearboxes that can (and do!) wire into the factory wheel paddles.
EG: https://www.powertraincontrolsolutions.com/Performance_Aftermarket/Products/Transmission_Products/TCM-2000_Transmission_Controller/
(or the new 2800, I have the 2000, well I'm trying to sell the 2000).
That option however is expensive, because it's what I did and I lucked out on someone who knew the gearboxes. Literally exhausted options and asked someone at work whos partner "is a mechanic and may know someone" just turned out to be an expert in that specific type of thing.
It cost me about $10,000AUD once all was said and done, when you factor in the cost of torque converters, coolers, lines, hoses, sensors, labor of gearbox coming in out in out in out, flex plates (stock one does NOT handle the power), the TCU, the TCU tuning, and all the magic custom work that went into the actual gearbox, and I'm trying to sell it for $3500 so it goes to show that the money doesn't come back to you if you can find someone who will do the overhaul.
I would almost say this is a scenario where selling car and buying something like an Evo X or a Golf R or something that comes with a DCT nowadays is going to be a better car for your needs.
  • Like 1
Dude any chance you find out a shipping quote to mainland England uk for transmission the uk is crap for automatics I've tried a few big garages with no joy as of yet I don't need to sell my r34 I have a r35 gtr as my daily running phase 5 ecutek 650bhp so I don't need to use skyline much but the r34 was the dream so it has to be done some how very interested in your box now what does it come with ?
Thanks for help appreciated [emoji1303]
  • 3 weeks later...
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
