Replacing Manifold Studs
Hey guys, I really have no idea how to start as I am pretty new to the whole world of fixing/replacing parts for my car. At the moment I am at the point of doing my manifold as they have no studs what so ever so I got 12 new ones and really do not know how to get to it or what to do to fix it and I would love to do it by myself. If there is a DIY tutorial anywhere here can someone link me or if not, just guide me as what to do, will want to start it this weekend and I will post pictures. So far I know i have to take off the J piping and the turbo, but still pretty unsure. Any help is highly appreciated. :)
https://www.sau.com.au/forums/topic/471582-replacing-manifold-studs/
Put aside a full weekend for the job. You will have to remove all piping around the turbo then disconnect the downpipe and coolant and oil lines going to the turbo (have bucket ready when removing coolant hoses). You should be able to undo the manifold from the block with the turbo still attached but it might be easier to remove the turbo first.
Once you get the exhaust manifold off you will have to drill the studs, use an easy out to remove them, then put the new ones in (google this step).
Put everything back together. Pour a bit of oil into the turbo oil feed before you connect the line so it doesn't run dry on startup. Before you start the car I would also disconnect the cas and crank the car over about 20 times to get oil circulating through the turbo.
Things you will need:
-new manifold studs
-new manifold gasket
- new t3 turbo gasket (if you remove turbo from manifold, but it can't hurt to put a new one anyway)
-new dump pipe gasket
- new copper washers for turbo lines (i picked up a big box of assorted ones from united tools for $20)
  • Like 1
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
