Installing Side Skirts??? URGENT
Guest RedLineGTR
My R33 Gtst When it came over from Japan never came with side skirts and rear pods, very stockish I guess the full type-m body kit was an option...
My problem is that I have found some factory type-m side skirts but before I buy them I am wondering how the hell do you mount them??? Especially the side skirts?? Since I just had a look at the car and even underneath I can’t see any decent holding points.
Just need to know if anyone has removed their side skirts before:
How do they come off and how do you get them on??
How they actually mount the car??
https://www.sau.com.au/forums/topic/47159-installing-side-skirts-urgent/
Guest RedLineGTR
Thanks for the quick reply. Here are some pics I have found of the factory side skirts. But I’ll still going to see the side skirts in the flesh to make up my mind before I buy them. Not that keen on drilling holes into the body :(
Hope to get some more feedback from people :)
Thanks For your Time. Rob
Yup you can see the 2 bolt holes either end, plus maybe 2 bolts along the middle on the inside and its done.
Just pay the money and get it done professionally is my only advice, even if you have to wait an extra month to get it done :)
Guest RedLineGTR
Yah i'll see how it goes, since i know i have holes for bolts near the front guard but nothing on the rear knore on the bottom. Maybe i'll use double sided tape :) j/k I"ll just have to wait and see :(
Rob,
From the factory they attach with a series of clips into the door sill and 2 screws at either and.
I was in the same position as you, car had no skirts when I imported. I glued my skirts along the door sill (its easier, less fiddly and just as strong) and screwed at either end.
Hope this helps
Guest RedLineGTR
Life savers :rolleyes: sweet thanks for the info. If they just clip on and bolt on thats sweet saves me trying to get them into my car i can just clip them on!! on the spot too :rofl: saves them sticking out the windows. Thanks Again. Will let you guys know how i go tomorrow will be picking up some freshly paint sideskirts and rear pods for a good price.
Cheers Rob :D
No you have misunderstood, sorry. Since your car did not have skirts from the factory it doesn't have the holes to clip onto. You need to drill these holes and put a plug into the holes, which a clip will then clip into. The alternative is to glue them, and not drill any holes, which is easier :rolleyes:
Guest RedLineGTR
Ah...that makes it clearer..cos i remember somewhere i saw a photo of all these clips/plugs on the side of the car when a sideskirt was removed and i wasn't sure if it was those. Hmmm dont know if i want to glue them. if the screws hold them in place half decently i'd rather use double sided tape since if i do intend to remove them sometime i wont loose half my paint from the glue :rolleyes: or i just might decide that i dont want to bother with them.
sideskirts are easy as to install and so are rear pods. if your car has mud guards there gonna have to come off. and u just use those holes. and then on the rear of the side skirts your gonna have to drill new holes to fit them. also by some stuff called sikaflex from most car stores and put a few dots on the top of the skirts to hold them in place
Yeah i was told to use sikoflex as well as drilling two holes or so to mount the sideskirts. As for the pods- if they're fibreglass copies taken from a mould may be a bit of mucking around, especially pressing the lip part up and around the rear bar. I used tiny plugs to hold that curving part in, but my car is black so can easily get away with it. The end result looks really neat and professional, but there was a bit of mucking around involved. Otherwise just take it down and get someone else to do it!
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
