FS [SYD]: Splitfire Coilpacks w/ Box | Coilpack harness | Coilpack bracket & bolts
Hey Girls and Guys!
So you may know or probably not know - I bought a NEO motor. This means majority of my R33 RB25DET stuff is pretty much useless on this motor.
I have a wonderful load of items for sale for such a lucky person! No more misfires, no more coloured coilpacks that aren't blue dropping out and causing ECU outputs to short circuit or ECUs to shut down. These are the real deal, no bullshit Splitfire SF-DIS-005 Coilpacks!
You're thinking, this guy actually kept the original box? yeah I sure did! I always wanted to sell them and convert to Yaris coilpacks one day, but that "one day" turned out to be 4 years! Anyhow, enough random bullshit this is the break down:
  • $300 - Splitfire Coilpacks with the original packaging
  • $50 - OEM Nissan quality coilpack harness, no cracked clips!
  • $50 OEM Nissan quality coilpack harness for RB25DET motors (long live the VCT!)
Because I am Asian, there will always be a best pry cash deal. I do speshcal pry, $350 you tek de lot - kesh only.
Price: $350 the lot
Fitment: ECR33 S1.5/2 (no ignitor pack) and BNR34
I will only post if you direct deposit - no PayPal because there are too many dodgy scammers out there. Pick up > Post.
5 hours ago, john boost said:
Hey mate would you sell the coil pack harness seperate?
Sure will!
OEM coil pack harness no longer for sale. Turns out the R34 NEO and R33 will work however the plug lengths are incorrect as the coil orientation is different. Schematically the harnesses are identical.
Now for sale is my Wiring Specialties R33 RB25DET S2 coil pack harness. This is about 1.5 - 2 years old or so.
$100
I said you could borrow it before lolol..
I thought I could use them on the NEO head but it doesn't fit :(
Coils are sold
Coil brackets are sold
Still left, Wiring Specialties Coil pack harness.
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
