Recommend me a turbo/cam setup- RB25
ironmcl
 Share
Hi all,
I'm hoping someone can save me the money on spending on a new setup that doesn't meet my needs. I've currently got about 330kw with an old garret 3080 0.82 housing through a built RB25 on E85. I'm running 25psi currently and would like to upgrade cams and springs, thinking while I'm there to do turbo, manifold, gates etc.
I'm looking for about 450kw give or take, preferably give.. So far im thinking of either a 6466 or a gtx3584rs?
When it comes to cams, I don't mind losing the VCT if its more beneficial to do so. I don't really have a cam selection in mind. Everyone loves that lumpy idle but am unsure of what to get.
Currently the car is only used a handful of times a month. Mainly drag use/roll racing with some street driving (not daily driver).
Just looking for advice, maybe from people who have gone down a similar path or someone who can guide me in the right direction.
Cheers
What housing do you have on the 8374 and what power you making at what psi mate?
twin scroll or nah?
I don't mind the cam noise, car is barely driven. Just after performance if noise is there great if not that's fine too
I'm fitting a 9174 soon with 1.05 housing. If I was in your position I'd go with a neo engine and 8374. I've used Borg Warner turbos that are essentially s300 airwerks and love them. I did have a neo manual stages years ago with a trust t67 which was ok but poor compared to today's tech.
I'm looking at fitting vcam to rb26 too. I'd definitely keep vct.
If near Newcastle I can take you for a drive to give you an idea.
4 hours ago, Scott Black said:
Fwiw a gtx3582r will make the power you want. Your not going to want anything more than just mild drop in cams for that level anyway. However would recommend replacing the valve springs anyway.
Yeah I considered the 3582r. But thought would rather overshoot then upgrade again in 6 months time to be honest.
definetely doing sprints but still uncertain about cams and size
Get a Precision 6466 and Tomei Poncams.
I'm just saying that because that is what I will be using on mine but probably won't get around to fit anytime soon but it would be interesting what results that setup is capable of .
EFR8374 and Tomei Pon cams.  The EFR8374 is proven time and time again to go >450kws and is responsive as hell for a turbo capable of that, the pon cams retain VCT and the setup should stay perfectly streetable.  A 6466 or a GTX3584RS are both serious overkill.
  • Like 2
Would you be suggesting t4 twin scroll setup with a .80 something housing?
I did originally like the setup idea but seemed like a fair whack of fab work involved to get it all to work and sit in the bay. I could be wrong tho
Edited by ironmcl
Error
1.05a/r twin scroll setup.  I know it sounds big, but trust me on that - it'd be the go.
No matter what you'll be down for a bit of fabrication for that power level, what packaging limitations or preferences do you have?  Are you preferring to stay single entry?   In your position I'd personally be looking at a GTX3582R if single entry was the preferred choice, or EFR8374 if twin scroll was an option.  Both are very potent turbos and ideal for that mid 400kw @ wheels range on E85
  • Like 1
I'm assuming I couldn't just slap on a 6boost t4 manifold to suit the turbo and housing? The only reason I was considering just doing the single entry was due to less stuffing around. It does make more sense though to do it once and get the better outcome of the twin scroll setup.
Ive read before about the larger housing being more ideal so not doubting you at all.
To be honest I'm not sure how much fab work would be required to get it to work and mainly fit I assume?
How much boost do you think the setup would want if you had to have a guess?
1 hour ago, ironmcl said:
I had a play around then, tried to not change too much just obviously the must have info. In regards to boost how would I know what to type in for each part of the Rev range?
You play with the boost at each rev point to get the operating line running through the best efficiency part of the compressor map.  You can't make the boost so high that it goes over the surge line.  You can't make it so low that it falls off the right hand side of the map.  You can't set it so that you need a stupid turbine to run it. It's all a bit of trial and error.  But once you've played with a it a bit, it makes perfect sense.  In fact, watch the Youtube videos put out by BW to get the explicit instructions.  Makes it easy.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
