Recommend me a turbo/cam setup- RB25
Hi all,
I'm hoping someone can save me the money on spending on a new setup that doesn't meet my needs. I've currently got about 330kw with an old garret 3080 0.82 housing through a built RB25 on E85. I'm running 25psi currently and would like to upgrade cams and springs, thinking while I'm there to do turbo, manifold, gates etc.
I'm looking for about 450kw give or take, preferably give.. So far im thinking of either a 6466 or a gtx3584rs?
When it comes to cams, I don't mind losing the VCT if its more beneficial to do so. I don't really have a cam selection in mind. Everyone loves that lumpy idle but am unsure of what to get.
Currently the car is only used a handful of times a month. Mainly drag use/roll racing with some street driving (not daily driver).
Just looking for advice, maybe from people who have gone down a similar path or someone who can guide me in the right direction.
Cheers
https://www.sau.com.au/forums/topic/471627-recommend-me-a-turbocam-setup-rb25/
What housing do you have on the 8374 and what power you making at what psi mate?
twin scroll or nah?
I don't mind the cam noise, car is barely driven. Just after performance if noise is there great if not that's fine too
I'm fitting a 9174 soon with 1.05 housing. If I was in your position I'd go with a neo engine and 8374. I've used Borg Warner turbos that are essentially s300 airwerks and love them. I did have a neo manual stages years ago with a trust t67 which was ok but poor compared to today's tech.
I'm looking at fitting vcam to rb26 too. I'd definitely keep vct.
If near Newcastle I can take you for a drive to give you an idea.
4 hours ago, Scott Black said:
Fwiw a gtx3582r will make the power you want. Your not going to want anything more than just mild drop in cams for that level anyway. However would recommend replacing the valve springs anyway.
Yeah I considered the 3582r. But thought would rather overshoot then upgrade again in 6 months time to be honest.
definetely doing sprints but still uncertain about cams and size
Get a Precision 6466 and Tomei Poncams.
I'm just saying that because that is what I will be using on mine but probably won't get around to fit anytime soon but it would be interesting what results that setup is capable of .
EFR8374 and Tomei Pon cams.  The EFR8374 is proven time and time again to go >450kws and is responsive as hell for a turbo capable of that, the pon cams retain VCT and the setup should stay perfectly streetable.  A 6466 or a GTX3584RS are both serious overkill.
  • Like 2
Would you be suggesting t4 twin scroll setup with a .80 something housing?
I did originally like the setup idea but seemed like a fair whack of fab work involved to get it all to work and sit in the bay. I could be wrong tho
Edited by ironmcl
Error
21 minutes ago, GTSBoy said:
I had a play around then, tried to not change too much just obviously the must have info. In regards to boost how would I know what to type in for each part of the Rev range?
1.05a/r twin scroll setup.  I know it sounds big, but trust me on that - it'd be the go.
No matter what you'll be down for a bit of fabrication for that power level, what packaging limitations or preferences do you have?  Are you preferring to stay single entry?   In your position I'd personally be looking at a GTX3582R if single entry was the preferred choice, or EFR8374 if twin scroll was an option.  Both are very potent turbos and ideal for that mid 400kw @ wheels range on E85
  • Like 1
I'm assuming I couldn't just slap on a 6boost t4 manifold to suit the turbo and housing? The only reason I was considering just doing the single entry was due to less stuffing around. It does make more sense though to do it once and get the better outcome of the twin scroll setup.
Ive read before about the larger housing being more ideal so not doubting you at all.
To be honest I'm not sure how much fab work would be required to get it to work and mainly fit I assume?
How much boost do you think the setup would want if you had to have a guess?
You play with the boost at each rev point to get the operating line running through the best efficiency part of the compressor map.  You can't make the boost so high that it goes over the surge line.  You can't make it so low that it falls off the right hand side of the map.  You can't set it so that you need a stupid turbine to run it. It's all a bit of trial and error.  But once you've played with a it a bit, it makes perfect sense.  In fact, watch the Youtube videos put out by BW to get the explicit instructions.  Makes it easy.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
