Hey listen i will give u the small run down, basically i have got a RB26 crank and rods for my engine rebuild and also 86.5 Ross forged pistons, i got a GTR intake plenum, gtr fuel rail, gtr injectors, gtr reg and pump, N1 oil pump, HKS 1.6mm headgasket and 256 cams. Now basically my question is, am i going to be able to put all this together and still run the motor on the standard RB25DET computer?? The reason i ask this is because i dont really have the money at the moment for an aftermarket computer so all i want to do is drive it round, not wanting to make any power on it or anything i just want it to be driveable and do no damage to the engine, i will have to run the motor in for awhile so im not going to stuff anything up in a hurry, since the compression will be altered via the crank, cams, headgasket and machining the combustion chamber in the head i believe this will affect the computers way of controlling things a fair bit??/ ANYONE have ANY ideas?
https://www.sau.com.au/forums/topic/47166-running-gtr-crank-with-gtst-computer/
Guest two.06l
noone?? any ideas?
seems strange to invest all that money and risk your engine on a poor tune.too rich will not allow proper bedding in and too lean could damage bottom end my suggestion is not to be silly and risk it.if you cant afford proper management/tune the you defineately cannot afford engine damage....paul.....DIRTgarage
The ECU/computer should have been bought before these list of mods took place.
I think runnning the gtst computer standard without any piggy backs at all may be a problem. At least an SAFC may be able to help a little. Might be a little risky as mentioned plus i would say that air/fuel mixtures might be out a little which is where the SAFC would help.
Check out investing in a WOLF ECU or an Apexi Power FC they seem to be the general standard in ECU upgrades on the SAU forums.
Dont chance a stock ECU with those mods.
with all the $$$ there, i wouldnt think of doing it on a stock ECU, let alone starting the car.
actually, GTR injectors i dont think work with a stock ECU, i stand to be corrected there though.
$1100 PowerFC delivered. not like they are hell expensive ATM.
ok, well i was only planning on running the motor like a grandma until i got the extra $$$ to buy the power fc and avcr. II understand that 1100 isnt expensive but i sorta stretched myself as far as i could with this build to do the motor properly whislt its apart this time. Would like to know more about the gtr injectors not being able to be run with standard ecu though!!!
shall do, hopefully i can driv eit there, motor is still out of car though, block is getting bored, honed, decked n o-ringed, plus porting head, cams are gtting reground, so when thats done, i can put it back together, although afew custom things have to be done. Thanx
