R32 Gtr fuel pump wiring
Hey there, I have a r32 Gtr which is running a nismo lift pump to 2 Bosch 044s and a surge tank. I've wired all three pumps up to new relays all getting power source from the battery in the boot. Each pump has their own earth which are solid, sort and to bare metal. During my wiring of the pumps I removed the factory pump relay. I just need a hand getting the right switch feed for my relays. I'm currently using a 12v accessories wire in the boot as the switch wire for the relays so the pumps receive 12v as soon as the keys are on accessories. What I'd like to know is which wire should I use for the switch of the relays ( I thought it was pin18 black and pink) out of the ecu but that wire has no power from it. Any assistance would be great for what wire people use from the ecu.
Cheers
https://www.sau.com.au/forums/topic/471678-r32-gtr-fuel-pump-wiring/
3 hours ago, KiwiRS4T said:
2 hours ago, Ben C34 said:
Also, the relay main power should go direct (woth a fuse) to the battery, not through another relay or accesories. What you have done sounds wierd.
Yeah I have each relay getting power from a fuse block I have in the boot all with 50amp wiring. My current trigger wire I'm using is a 12v acc wire which is turning the pumps on. They are all turning on fine I just wanted it to be correct.
10 hours ago, Thrillhouse said:
Correct. It's currently wired like the picture with the trigger getting 12v from the ignition.
This is bad and unsafe. As someone else mentioned, should probably get a pro.
In case of an accident you don't want pumps running, which they will be if getting trigger from IGN/ACC.
  • Like 1
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
