R32 GTR won't start, please help
So I am running short on ideas to get my car started, part of this thread is copied from another question I posted about the CAS which was answered (thank you!).  I have searched around for similar issues and I feel like I have attempted all the solutions people had success with when having similar issues.
The car is a 1991 GT-R was delivered to me back in February in partially running condition.  It would miss sporadically at partial throttle and would die out the moment I let off the gas.  Since then the car has stopped running altogether.  The last time I took it around the block to test a repair it was extremely hard to get restarted and keep running.  Each time it died I had to crank on the starter for 15-20 seconds before it would fire up and then I had to keep my foot on the gas so it wouldn't die.  I limped it into the garage and it has been sitting there since.  The car will turn over but will not start.  Sometimes I get a backfire.  The only code the car was throwing was for "ignition", I think it was a 12 but it has been a few months since I checked it.
I do not know all of the modifications aside from what I have found by visual inspection.  The engine mods include:
RSR 4" cat-back
Greddy downpipe
R34 GTR stock turbos (not N1's)
Mine's intake
Blitz BOV's
The intercooler has NISMO on it but I haven't checked the plates on the core to see if it's legit
Work done so far:
Opened both MAF's to check for loose solders (all connections were good), cleaned both MAF's
Cleaned air filters (Mine's intake with K&N's)
New NGK BCPR7EIX Iridium plugs (it had some ngk race plugs installed when it arrived)
New battery
New coil packs
New coil pack wiring harness
New fuel pump (aeromotive 340)
New fuel filter
New ignition module (the old one tested bad and I really hope this would solve the issue haha)
Tried to start the car with starter fluid (sprayed in behind one of the mafs to avoid messing it up)
New CAS
Thanks in advance for any feedback, suggestions, or input!
Brock
https://www.sau.com.au/forums/topic/471684-r32-gtr-wont-start-please-help/
The only good way is to take them out and send them away for proper cleaning and testing. But in the meantime after you have attempted to start the car pull the plugs out and see if they are wet. You need to try to establish whether you have a fueling or spark issue.
  • 3 weeks later...
I had a similar issue a few week back with my R32 GTR had been sitting for 5 years and the time it right to get it back on the road. So new oil, new plugs, new battery and a new fuel pump and it would just crank and crank and crank with not even a hit of firing. It had spark and proper signal to the injectors just not enough power to get them to move so put 12v direct from the battery to each injector and that was enough to free them now starts and runs fine ever start.
  • Like 1
Thanks for the heads up, I may give that a shot.  At this point the plan is to just pull the injectors and ship them off to have them rebuilt and balanced as the cost isn't that bad.  I took a video last night that I will try to attach.  I pulled the CAS and spun it with the car keyed on and I can hear it sparking.  There is also a humming noise that accompanies it that sounds like it is coming from around the FPR as near as I can tell.  Does this clicking sounds pretty spot on? Does anyone know if the humming sounds are pretty typical?
I also connected a spare ecu and tried to start the car with the same result.  When I pulled the plugs after trying to start the car they for sure smelled of raw fuel.  Maybe they're stuck open and flooding the motor?
Thanks,
Brock
IMG_1277.MOV
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
