Need advice on choosing manifold - rb26/30 single turbo GTX4202R
Hi all
I'm currently in the process of dummying up the fitment of my garrett GTX4202R on my rb26/30 and of course running into some fitment issues.
1) First issue is the clearance between the turbo and the block - the compressor housing fouls against the rocker cover by maybe 1-2 mm. Might be able to either relieve the rocker cover or offset grind the cylinder head flange by 1mm or so to angle it out slightly. EDIT: or does anyone make an exhaust manifold insulator/spacer? even 3-5 mm would probably do it.
2) second issue is more difficult. the manifold seems to sit the (admittedly huge) turbo too high in the bay to shut the bonnet. This is probably not assisted by the fact that I already have an extra 38mm of deck height due to running the rb30 block.  But it's so close I won't really know until I dummy it up.
It's a nicely designed mx motorsports steampipe manifold with a nice collector and having done some measurements with a spare block, it's going to be a game of millimeters. But just want to know if there are any manifolds which sit the turbo nice and low in the engine bay, while still clearing the a/c - I would prefer to just buy something ready made and minimise the amount of screwing around if possible, in the event it comes to having to buy a new manifold.
any suggestions gratefully appreciated. Oh, needs to be twin-scroll T4 flange, and if possible twin 38mm v-band gates.  Or, custom. Some that I've seen also angle the turbo out sightly so the intake is looking more to the passenger-side headlight.
Cheers
Andrew
Edited by dorifticon
Goodluck with it, I'll be dummy fitting my 68/70, hopefully in the next couple of days. I measured what I can and I'm in the same boat as you, I think it's going to be a game of mm! Mines a 26/30 as well so always fighting for mm when it comes to under bonnet clearance lol
6 boost make a 26/30 specific manifold that clears everything and has good clearance for bigger turbos. I am running one of their manifolds in twinscroll t4 albiet with a single 60mm gate just to help with space however the 6870 clears no worries. Motor is a 3.2 sitting on standard mounts with crossmember in standard position.
what type of mods are we talking - removing sections of the bonnet ribbing or something more serious?
Also what wastegate setup- single or twin? retaining A/C?
Finally, - what brand is the manifold?
  • 3 weeks later...
Hi dorifticon, manifold is a custom job for a guy who works out of the JEM workshop.
I'm running a single precession wastegate that came with the turbo .
Bonnet mods, just needs a small section of the ribbing removed. The bonnet actually closes but is raised about 5mm on the turbo side, obviously from hitting the turbo, the ribbing is about 30mm at that point and hits the cold side of the turbo so once cut should be all good. I've also had the manifold and turbo ceramic coated to help deal with the heat
I had the same issue
ordered a "gt42" 6 boost manifold for my r32 gtr 2.8 stroker and my 7175 didn't clear by miles
got sent another one which didn't clear either
ended up buying a custom made turbo1 manifold with twin external 38mm wastegates
turbo sits perfect now between turbo and bonnet, turbo and strut tower and most importantly clears AC lines
Oh yes that was the other part of the question, yes I have AC and it cleared the lines by a mile.
Didn't quite clear the bonnet but it was made for an r34 with an rb26 not a 32 with a 30/26.
And since the bonnet has already been slightly modded for engine clearance I'm not fussed in cutting it a little more
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
