For sale 2000 R34 Gt-T coupe
3/2000 ER34 GT-T in Silver
I Have owned the car for 5 years and it was only daily driven for around 2 of those the rest of the time it was garaged under a car cover I purchased it at 107,000k's and it now has just over 139,000k's so it has only traveled
around 30,000k's in 5 years,In that time it has always been looked after I changed the oil and filter every 3-4000k's or 6 months and only ever used Royal purple full synthetic 5w40 and also changed and flushed the gearbox oil
once a year with castrol Tranzmax z full synthetic,Brand new battery just fitted and will come with 6 months Rego and Rwc.
Vehicle was purchased completely stock
Modifications are as follows
Stock engine
Apexi power intake kit
JJr custom air box with custom air feed
Z32 air flow meter
Custom turbo air intake pipe
Hks 2540 turbo
JJr 3 inch stainless steel front pipe
Hks silent power cat back exhaust
Greddy return flow front mount intercooler kit
Nismo 480cc injectors
Walbro Gss342 255lpoh fuel pump
Splitfire coil packs
Nistune Ecu
Greddy profec oled boost controller
Gearbox
Mv Automatics stage 2 shift kit
3000 Rpm stall converter
Wheels/tyres/Brakes and suspenison
Works wheels 17x9.5 rear 17x9.0 fronts
Works rs blue wheel nuts
Nitto Nto5 255/40r17 (new)
Endless super street M-sport pads all round (almost new)
slotted and dimpled front rotors (almost new)
Pedders front comfort shocks
Low King springs all round
JJr pillow joint front caster rods
Tog adjustable rear upper arms(0 camber for best traction with Nittos)
Interior Pretty much Left standard apart from
Lager shadow pro volts/oil temp/boost gauges for gauge pod
and all interior lights have been replaced with blue led bulbs
Pioneer Mechless Head unit with blue tooth and speaker
6 Inch sony speakers front and rear
Vehicle was tuned by PITS making 225Rwkw with a manual bleed valve that bleed down to 14psi but with the Greddy profec it holds 18psi
Price is $14000 negotiable
Hardly Ever on here anymore so please send me a txt on 0431 720 seven seven one
https://www.sau.com.au/forums/topic/471702-for-sale-2000-r34-gt-t-coupe/
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
