18x11 fitment on 32 gts
Hi guys,
Just curious to see if anyones gotten close to these specs on their R32 gts/gtst. Wheels are 18x11 +8, will be running a 225/40 tyre and -12 camber on the front, -6 on the rear.
Don't worry this is all for a show in 6 weeks, no way in hell I'm driving like this anywhere. Just wanted to know what tyre/camber others have had to run with 18x10.5 or even 18x10
Cheers.
https://www.sau.com.au/forums/topic/471722-18x11-fitment-on-32-gts/
Good luck with that. Lot of camber, but not sure it's gonna be enough!
Wider guards on GTR need 4-6 degrees to fit 10.5 wide +15 on the rear I think. Gtst will be harder. Then you got another 33mm to go with those sized wheels.
23 hours ago, niZmO_Man said:
225 wide tyres on an 11" wheel.
Just make it fit, you won't be driving it anyway
Yeah they'll be going on for a 10 minute drive to a show then coming off after the show aha. No way I'm driving to sydney with that little tyre and that much camber.
  • 5 years later...
Hi guys,
Cheers.
just fit 9.5 +38 with a 265 35 18 with hardly any camber and have some self respect
what show? you will be laughed at, or is that show where everyone stands at the entrance watching cars try to drive over a 10mm bump laughing and filming the clowns driving in as ebay body kits break off.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
