Splitfire RB25DET S1/S2 Coil Packs, RB25DET S1/S2 CAS, R34 NEO stuff.
Hello,
Have the following for sale, located in Wollongong NSW (2500):
6x RB25DET Splitfire Coil Packs to suit RB25DET S1/S2 motors. Only reason for sale as went RB25DET NEO and have upgraded ignition. 6-8 months use in perfect condition - $300
Nissan RB25DET S1/S2 CAS, in good working order - $150
R34 NEO Intake Manifold, complete with rail and injectors, IACV, throttle body etc - $150
R34 AC Compressor - $150
R34 Engine Mount brackets - $30
R34 NEO Engine Cover - $50
R33 Turbo Exhaust Manifold, good condition/no cracks/straight/flat - $80
R33 Golpher Racing Radiator - straight/no dings -- old motor did blow head gasket very minimal oil, have cleaned out and bathed the radiator, but probably need a hot flush - $50
Can get pics if needed, but pretty sure everyone knows what it all looks like.
Feel free to PM and I will get back to you if you are interested at anything.
Cheers,
Noobles
Edited by Noobles
Coil packs are different between S1 and S2. The latter has built-in igniters. Which one have you got?
S1/S2 CAS are also different, but unsure of interchangeability.
S2 coil packs with built in igniters... can be used on S1 with S2 loom or modifying existing (I should of stated though).
It is a S2 CAS, but will work on S1 (well I have done this in the past in my experience).
Cheers.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
