Two faults with my v36
So I have two faults with my v36 manual coupe and wondering if this is a common thing.
One is the clutch sticking to the floor on spirited take off's and the second is axle/driveline shudder or bounce with wheel spin on certain surfaces.
The worst of the two is the clutch that I'm pretty sure is a clutch slave cyclinder problem... Again!!
When I got the car I found that the clutch felt fine until on the occasions I did a spirited take off with some revs/throttle and "clutch control" (not riding ha ha) for a good take off. The clutch would stick half way to the floor until I either backed off or pulled the pedal back manually. I nursed the clutch from then as occasionally the clutch would slip when this happened. Absolutely no problem with the clutch on normal driving, nor full throttle when the clutch was fully out. Just couldn't give full throttle before the clutch was out.
Anyway, so after they changed the clutch fluid, then the master cylinder it came down to the slave cylinder which fixed the problem. Scored a new stock clutch plate out of it as well as the master cylinder which didn't need replacing.
Problem is it has now come back after less than 20k. I don't usually abuse the clutch however, with reviews matching on down shifts and usually low revs to take of so not riding the clutch.
Thing is I have driven manual for most of my life and neither of my s15 had this problem with the last one close on 200kw at the wheels.
Is the v36 slave cylinder really this weak or have I just had bad luck? My take off's aren't that abusive. Just the odd spirited take off I'd expect any performance car to be capable of on occasions.
The other problem is the shudder (feels like the old school axle tramp on a live axle car) I get occasionally on minor wheel spin with traction turned off. It doesn't always happen, and it can often happen on minor wheel spin on take off. I've had it in the wet multiple times as well. I've got some decent high performance tyres (pilot sport 4S) but this also happened on the re050a when they were rat sh!t grip near the end of their life. Could this be bush wear or something? I've got stick suspension except I have whiteline adjustable sway bars in it (although it did with the stock sway bars).
Edited by Pete_Repeat
https://www.sau.com.au/forums/topic/471744-two-faults-with-my-v36/
The clutch master and slave shouldn't care if you are at full throttle or at 1/10 throttle, it only has to release the clutch.  just taking a wild guess here but perhaps the twisting of the engine/transmission under a hard launch is causing the issue, have you had the flexible hose changed?  Otherwise, it could be a pressure plate or clutch fork issue.
As for the tramp/shudder, I would check rear suspension bushes.  Not sure about the V36, but the diff mounting bushes went bad after a while on the V35, so check these too.
I don't actually have a V36, so just giving some general suggestions.
  • Like 1
I hear you about the clutch. But it feels just like the first time where replacing the slave cylinder seemed to fix it for some time now. No problems with the original clutch plate then, just that I think they couldn't get the slave cylinder without the clutch plate included supposedly....
Flexible hose? Is that between the master and slave?
So diff bushes hey. I'll have a look at them. It does feel a little like it's something hitting the body so this makes sense. I recently got an alignment done and asked them to look at bushes but they wouldn't have checked the diff ones for an alignment
2 hours ago, Ben C34 said:
That type of behaviour is typical of factory clutches from many manufacturers.
Call a decent clutch place and discuss with them.
Oh right. I must have got lucky until now..
Might need to nurse this clutch for a bit until I feel I've warn it enough to justify getting rid of it or the slave gets worse, as I'm  not keen to replace an almost new clutch just yet.. I've changed clutches before but I'd likely pay someone next time and that won't come cheap I'm sure.
  • 4 months later...
It's the CSC. When it heats up it fails. I've had my clutch to the floor on a couple of occasions and luckily after it cools down it pops back up. There are upgrades available im sure through CZP or an elimination kit through Z1 motorsports.
Just remember when you replace it, you will "need" to buy a new Master Cylidner and replace it with it.
You will need to upgrade it or eliminate it.
Thanks for the reassuring.
I'll look into them when it gets worse again, or I need a clutch change.. Clutch has probably only done 20k so far I think, so hard to pull it out just yet.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
