Just wanting to know peoples thoughts/experiences on cold start with RB20 runnings cams.
I am finding it takes 3-4 attempts to start the car, it idles out and usually on the 4th go it's good.
The cold start idle is quite rough/fluctuates and varies between just about stalling to about 1500rpm while warming up.
Also warming up takes about 5-10 mins and driving it before warming up is not really possible due to the fluctuating idle.
Is this normal or does the tune need some adjustment?
https://www.sau.com.au/forums/topic/471749-rb20-cold-start-with-cams/
Bad tuner.
Needs more timing when cold and more fuel. Also you'll need more duty on the idle control valve.
You will need more cranking fuel and a bit of post start fuel.
What ECU? Send me your map.
