Mitch r33 Posted August 25, 2017 Share Posted August 25, 2017 R33 what power? Hey guys, Just wondering what power I'd be looking at with the following mods on my r33 s1; 3.5" turbo back, highflow turbo (hypergear, G3 with high pressure actuator), splitfires, 550cc injectors, z32 afm, r32 ecu nistune, fmic, blitz pod, walbro 255 Any rough guesses from previous experiences or if you know roughly in kw? thanks guys Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/ Share on other sites More sharing options...
admS15 Posted August 25, 2017 Share Posted August 25, 2017 250rwkw give or take 10 or so. Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846467 Share on other sites More sharing options...
Mitch r33 Posted August 25, 2017 Author Share Posted August 25, 2017 20 minutes ago, admS15 said: 250rwkw give or take 10 or so. Cheers, anyone else with similar mods know roughly? Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846472 Share on other sites More sharing options...
KiwiRS4T Posted August 25, 2017 Share Posted August 25, 2017 Have you had a look at the RB25 Turbo upgrade thread at the top of the page? 1 Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846474 Share on other sites More sharing options...
Mitch r33 Posted August 25, 2017 Author Share Posted August 25, 2017 Just now, KiwiRS4T said: Have you had a look at the RB25 Turbo upgrade thread at the top of the page? Nah I haven't, I'll try and find it now Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846475 Share on other sites More sharing options...
GeeDog Posted August 25, 2017 Share Posted August 25, 2017 250 - 270 sounds about right on P98, depending on how happy the dyno is that day. Your injectors will stop you going to E85, but if you upgraded them & tuned for E85 you would be looking around 300. Intake piping & cat may cause issues at that power level as well. Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846495 Share on other sites More sharing options...
Mitch r33 Posted August 25, 2017 Author Share Posted August 25, 2017 1 minute ago, GeeDog said: 250 - 270 sounds about right on P98, depending on how happy the dyno is that day. Your injectors will stop you going to E85, but if you upgraded them & tuned for E85 you would be looking around 300. Intake piping & cat may cause issues at that power level as well. Cat is de-cat (hollow) 3.5" and Intake piping what do you mean? Plenum? Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846496 Share on other sites More sharing options...
GeeDog Posted August 25, 2017 Share Posted August 25, 2017 Just now, Mitch r33 said: Cat is de-cat (hollow) 3.5" and Intake piping what do you mean? Plenum? No, the rubber pipe from the AFM to the turbo - if you still have the stock one it will suck closed at the boost level you need to get over 250RWKW. Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846497 Share on other sites More sharing options...
Mitch r33 Posted August 25, 2017 Author Share Posted August 25, 2017 1 hour ago, GeeDog said: No, the rubber pipe from the AFM to the turbo - if you still have the stock one it will suck closed at the boost level you need to get over 250RWKW. Ok will change that too. I'm only going safe tune so roughly 17-20 Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846522 Share on other sites More sharing options...
inmaniac Posted August 25, 2017 Share Posted August 25, 2017 I have literally the same mods aside from the 550s (I have 740s) and I got 230rwkw @ 14psi - I would have gone higher but at the time I had a shitty actuator (which is now replaced). Your mods will net you 250rwkw-ish as stated but yes, replace the stock intake pipe for a solid one. Im going E85 in the next few months and all I need is a 460 pump upgrade, flex sensor, fpr for peace of mind and a tune and I should be in the 300 club Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846567 Share on other sites More sharing options...
vxsr33 Posted August 25, 2017 Share Posted August 25, 2017 I have literally the same mods aside from the 550s (I have 740s) and I got 230rwkw @ 14psi - I would have gone higher but at the time I had a shitty actuator (which is now replaced). Your mods will net you 250rwkw-ish as stated but yes, replace the stock intake pipe for a solid one. Im going E85 in the next few months and all I need is a 460 pump upgrade, flex sensor, fpr for peace of mind and a tune and I should be in the 300 club Best bang for your buck way to get to 300rwkw imo. I wish i looked more into going E85 flex before i got a power fc. Link to comment https://www.sau.com.au/forums/topic/471756-r33-what-power/#findComment-7846572 Share on other sites More sharing options...
