Weirdest running rich problem above 3000rpm
Hi all.
Hope someone can help me with my problem.
I have an R32 GTR, freshly build RB28.
Mapped with Nistune. Car was running fine while we mapped it and also the day after that.
Next day it had the weirdest problem.
Car is running completly normal until exactly 3000rpm. Above 3000rpm the AFR drops to 10.5:1 instantly and stays there almost the entire rev range. Doesn't matter if I'm driving oder reving it in neutral.
It also doesn't matter what settings we make in Nistune. It's always the same above 3000rpm.
What we checked so far:
-both AFM have rising voltage with rev and load
-TPS has normal Voltage
-has 3000km old Splitfire coilpacks
-has 4000km old Mine's AFMs
-has 200km old Sard 850cc high impedance injectors and resistor delete
-tried a different CAS
-shows normal water temperatur
-shows normal IAT temperatur
-problem also happens with unpluged O2-Sensors.
Looks like some kind of limp mode to me, but can't figure it out.
I'm realy pissed with the car (again).
Hope someone can help me.
Edited by GT-R David
How much did the 2.8 kit cost? Spend a few bucks more and get a Link or such like. Also are they old school Sards? If so get some modern injectors and double check the settings. Have you replaced the fuel pump...tested fuel pressure?
I actually like the Nistune and would like to keep it.
And they are not old school Sard, they are the new type with 6 hole for better spray pattern. P&P kit for rb26 engine.
We also tried a completly new basemap and it was the same. So no problem in the settings.
Fuel pressure is spot on, Greddy in car gauge shows no drop or rise in pressure.
  • 1 month later...
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
