I imagine the cold start portion of the IAC assembly , wax pellet part , will stay open and the idle will stay high .
You need to run coolant through them for it to work as intended .
Originally it gets coolant from three places . The standard manifolds cast in water log , the fitting into the lower drivers side rear of the head , the rear of the original manifolds throttle body .
The GTt's IAC housing is meant to be a high point in the original cooling system which is why it has the air bleeder bolt .
A .
  • Like 1
Just to expand Adrian's post.....
The little one furthest to the right in your photo goes to the fitting on the top of the cast, ribbed, water gallery that runs along the length of the stock inlet manifold just above the runners adjacent the head.  The fitting that it connects to points straight up, and the hose that joins them is only a few inches long because it's not far away.
The next little one closer, the one in middle, connects to the small fitting on the rearmost of the two heater hoses, down pretty much immediately below the stock location of the IAC valve.  That hose is a little longer.
The third little one, closest to the main body of the IAC valve, connects to the rear port on the water path through the throttle body.  If you were not to have that, then on the other side of the throttle body that line continues on to the front bleeder, which has a few small coolant hoses connected to it.
You really can't neglect any of these connections.  I don't know if those useless Freddy manifolds have an equivalent of the stock manifold's water gallery.  If it doesn't, then I don't know what to tell you.
You don't have any photos so I'm sure I have it connected correctly?
Okay I understand now I'm just unsure about where the last one connects as my throttle body doesn't have coolant going through it ?
So it would ideally need to connect to the same general area as the front bleeder does, which is no doubt a mixture of the thermostat housing and possibly the water gallery on the manifold.  I haven't got access to my car to have a look right now.  Why don't you google up some pictures of R34 engine bays and have a look see at that area?
I mucked around lots recently with R33 RB25/N14 Pulsar GA16DE/S15 SR20DET IAC valves . Make note that the Pulsar N14's GA16DE version uses a smaller internal shuttle valve size , R33 RB25 and S14/15 SR20DET are same .
That aside , generally people use an adapter plate to fit R34 GTt IAC valve assemblies on the cast GR/Fredy manifolds intended for R33 RB25 .
With a bit of a rejig you could probably mount an R33 or S14 or S15 IAC assembly because none of these use the water heated cold start valve (AAC) .You can change the air pipe tube over between these last three IAC units to get R33's T shaped junction tube . There is a mounting pad on R33 and R34 RB25DET water pipe that bolts underneath any of these inlet manifolds . This is where the R33's AAC or cold start bypass valve mounts .
I tend to agree that these aftermarket manifolds often create as many problems as they solve and most reckon the R34GTt's OE inlet manifold is pretty adequate anyway . The sad fact of life is that no aftermarket RB25 inlet manifold lets you put the cold start/idle stuff where it needs to be .
I once thought removing the factory crossover pipe was a major PITA but once its been off a few times no biggie .
Well with the GTt setup you'd have to find a way to close that cold start side or use an adapter plate and possibly an R33 or SR20DET type IAC assembly .
If aftermarket your ECU may allow you to adapt an alternative IAC valve assembly that's big enough to do cold start and idle speed control electrically .
Aftermarket manifolds are never easy and many people reckon that in a road driven car performance can be less except right up high . Something to weigh up .
Okay thanks I'll put it together and drive it for abit and let you guys know how it runs
I run no IACV at all and my car cold starts fine and idles fine. About 10 seconds after cold start it is absolutely fine, before that idle will stumble a little under revs only. I live in Newcaslte NSW and it gets down to less than 10deg here. I just couldn't be bothered plumbing it in and i'm happy i didnt.
  • Like 1
Sweet good to know what did everyone do with this ? Just run a hose down to nothing so it can breath ? IMG_1504062055.102626.jpg
No that is you PCV. that needs to run back into the intake manifold after the throttle body.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
