I imagine the cold start portion of the IAC assembly , wax pellet part , will stay open and the idle will stay high .
You need to run coolant through them for it to work as intended .
Originally it gets coolant from three places . The standard manifolds cast in water log , the fitting into the lower drivers side rear of the head , the rear of the original manifolds throttle body .
The GTt's IAC housing is meant to be a high point in the original cooling system which is why it has the air bleeder bolt .
A .
  • Like 1
Just to expand Adrian's post.....
The little one furthest to the right in your photo goes to the fitting on the top of the cast, ribbed, water gallery that runs along the length of the stock inlet manifold just above the runners adjacent the head.  The fitting that it connects to points straight up, and the hose that joins them is only a few inches long because it's not far away.
The next little one closer, the one in middle, connects to the small fitting on the rearmost of the two heater hoses, down pretty much immediately below the stock location of the IAC valve.  That hose is a little longer.
The third little one, closest to the main body of the IAC valve, connects to the rear port on the water path through the throttle body.  If you were not to have that, then on the other side of the throttle body that line continues on to the front bleeder, which has a few small coolant hoses connected to it.
You really can't neglect any of these connections.  I don't know if those useless Freddy manifolds have an equivalent of the stock manifold's water gallery.  If it doesn't, then I don't know what to tell you.
You don't have any photos so I'm sure I have it connected correctly?
Okay I understand now I'm just unsure about where the last one connects as my throttle body doesn't have coolant going through it ?
So it would ideally need to connect to the same general area as the front bleeder does, which is no doubt a mixture of the thermostat housing and possibly the water gallery on the manifold.  I haven't got access to my car to have a look right now.  Why don't you google up some pictures of R34 engine bays and have a look see at that area?
I mucked around lots recently with R33 RB25/N14 Pulsar GA16DE/S15 SR20DET IAC valves . Make note that the Pulsar N14's GA16DE version uses a smaller internal shuttle valve size , R33 RB25 and S14/15 SR20DET are same .
That aside , generally people use an adapter plate to fit R34 GTt IAC valve assemblies on the cast GR/Fredy manifolds intended for R33 RB25 .
With a bit of a rejig you could probably mount an R33 or S14 or S15 IAC assembly because none of these use the water heated cold start valve (AAC) .You can change the air pipe tube over between these last three IAC units to get R33's T shaped junction tube . There is a mounting pad on R33 and R34 RB25DET water pipe that bolts underneath any of these inlet manifolds . This is where the R33's AAC or cold start bypass valve mounts .
I tend to agree that these aftermarket manifolds often create as many problems as they solve and most reckon the R34GTt's OE inlet manifold is pretty adequate anyway . The sad fact of life is that no aftermarket RB25 inlet manifold lets you put the cold start/idle stuff where it needs to be .
I once thought removing the factory crossover pipe was a major PITA but once its been off a few times no biggie .
Well with the GTt setup you'd have to find a way to close that cold start side or use an adapter plate and possibly an R33 or SR20DET type IAC assembly .
If aftermarket your ECU may allow you to adapt an alternative IAC valve assembly that's big enough to do cold start and idle speed control electrically .
Aftermarket manifolds are never easy and many people reckon that in a road driven car performance can be less except right up high . Something to weigh up .
Okay thanks I'll put it together and drive it for abit and let you guys know how it runs
I run no IACV at all and my car cold starts fine and idles fine. About 10 seconds after cold start it is absolutely fine, before that idle will stumble a little under revs only. I live in Newcaslte NSW and it gets down to less than 10deg here. I just couldn't be bothered plumbing it in and i'm happy i didnt.
  • Like 1
Sweet good to know what did everyone do with this ? Just run a hose down to nothing so it can breath ? IMG_1504062055.102626.jpg
No that is you PCV. that needs to run back into the intake manifold after the throttle body.
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
