45 minutes ago, adam wicks said:
Also this has 2 spots for vac hoses do they both go to the manifold ?
And this is a solenoid that is used to trigger (I think) the vacuum to the charcoal canister when the (factory) ECU determines that it is OK to do it.  So, no, both do not go to the manifold.  On the stocker, one would go to a vacuum source and the other snakes off towards the front of the car.
5 hours ago, adam wicks said:
Is it for vac?
Yes, but not in the way that you're thinking.  That pipe is visible there, and on the other side of the timing cover.  On the inlet side, it is connected to the plenum.  On the other side it is connected to the suction port of the charcoal canister.  It provides the suck that purges the canister (and fuel tank) into the engine.
The solenoid valve you posted earlier is also connected to both the plenum and the charcoal canister.  It is the switch that makes the valve on the charcoal canister open.  There's no flow in that line, just a vacuum signal.
All the plenum vacuum you could ever want is available off the many vac ports they added down the back end of yoru new one.
Did you decide to put this plenum on without making notes on how the original setup was plumbed up?
  • Like 1
I work shift work and every time I started pulling the standard stuff off I got called to work for 12 hour shifts so I lost track and that's been the problem ahha
On 8/30/2017 at 6:55 PM, adam wicks said:
It's not for gain it's perparing for top mount turbo setup coming soon
Ah yes, but I have a top mount neo and do not need this manifold :P
That said, you're in it, and it's on the car, so may as well finish it now.
  • Like 1
  • Haha 1
Sorry, but that makes no sense.  There is more than one way I can read your question and none of them make sense.
1. Are you talking about the small hose on the barb on the intercooler return pipe just before the blue silicon joiner?  If so, that is not stock, it has been put there by somebody else, so it could be for anything.  It could be connected to that boost controller we see behind the PS reservoir.  It could be for a boost gauge.
2. Are you talking about the boost controller in the background?  If you are, one side (the input side) must come from the turbo outlet or intercooler hot pipe.  The other side goes to the wastegate actuator.
That one (the barb, near the blue joiner) is stock on a R34 neo, it does indeed go to the power steering. It's used for speed sensitive power steering (somehow) and disconnecting it does result in some VERY heavy steering.. as well as a boost leak).
It runs from the PS to the charge pipe. It doesn't run to the plenum, so it'll go back to somewhere on your intercooler piping. If this doesn't exist, well you can block the hose if you like heavy steering all the time, or get a fitting put on your charge pipes.
  • Like 1
Yes the barb is factory on the 34s thank you glad you could understand haha
Thanks so don't delete it just put it back into the cooler pipes no problem thanks for explaining it to I wasn't sure what it was for
Nuh it's a power steering air control valve, it's only for bumping up idle when you turn the steering wheel. Mine's removed when I got a replacement pressure hose made up
Just block up the fitting that goes back to the plenum and the IC pipe
  • Like 1
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
