I just bought an M35 lower control arm with new bushings to replace my current lower control arm on my PM35.
According to Nissan EPC-Data, the M35 and PM35 axel parts are all supposedly exactly the same model numbers.
However, attached is the arm I bought and next to that that is the one that I have. (Note the spot where the sway bar link connects to)
Is there a reason they are different? Does the one I bought use different sway bar end links? I'm guessing it's from the AWD model
Edited by NicPM35
  • Like 1
https://www.sau.com.au/forums/topic/471824-pm35-lower-control-arm-confusion/
Looking at nissans parts program rwd front suspension is different to awd suspension.
the lower control arms are different and the one you bought is an awd lower control arm.
here is the front suspension section from nissan fast's exploded diagram that may be able to help you showing the differences between awd and rwd
  • Like 1
  • Thanks 1
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 馃
    • Any difference in induction noise?
    • I think you know exactly who I mean.
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
