R33 Rb25det pcv HELP PLEASE
I'm about to do my own service on my first r33, because i don't know how  well the previous owner took care of the car, Can anyone tell me how to locate the pcv filter on a factory stock rb25det engine or some method of removing and cleaning before i later on change the valve cover gasket. Thankyou
https://www.sau.com.au/forums/topic/471910-r33-rb25det-pcv-help-please/
Errr, are you talking about the PCV valve?
You shouldn't have to do anything with that valve unless it is damaged or leaking.
I think you need to clarify what you're actually trying to do mate. If you're servicing the car, generally speaking you don't touch the PCV valve or breather system, unless there's a fault as I mentioned.
As for servicing itself, there are dozens of threads on this site. Use the search bar "R33 service". I suggest doing research before touching anything.
Good luck.
