A little help interpreting these export documents
Well, as long as you have the flex fuel kit you can use any ethanol mix. Also FYI the pump e85 varies between about e70 and e85 across winter and summer from most pumps
By PotatoCake · Posted
I only found out about Jesse's shop after meeting with A4E and having a good chat about what direction to go in with the car and exhaust setup. I didnt want to go back on my word as thats a bit of a shitty move, especially since Luke took the time to meet with me and have a really good chat. Theres not many places that do that anymore, most of the larger commercial workshops churn through the process like a production line, quantity over quality etc. -
On my platform, lpfp, Hpfp, injectors, Flex fuel kit..
Hi Fred, Are you still on here, I'm looking for 4 of these rims?
Looking back, I’m pretty sure I over-torqued the magnetic drain plug because I was trying to fully crush the copper washer. In hindsight, I definitely should’ve used a torque wrench. Either way, I ended up switching to a regular drain plug so I don’t have to deal with this kind of issue again. Big thanks to everyone on the forum for your support—I actually talk about you guys to my friends and coworkers
