Aem infinity
Any one run or have experience with the Aem Infinity Ecu. I have one in my garage from my last project car. I cant justify spending a bunch on a power fc if the infinity will work.
I will be running it on a r32 gtr.
Also when is a good time to throw a tune on the car. I will be putting full exhaust and intake on soon. No boost restrictor is in place either.
https://www.sau.com.au/forums/topic/471951-aem-infinity/
But AEM ECUs will have massive issues with the Nissan CAS and their solution is to crack open your CAS and install their disc.
What's wrong with that? Autronic do the same thing. Halaltech tell you don't have to, but you really should.
https://www.sau.com.au/forums/topic/471951-aem-infinity/#findComment-7849387
Should speak to Andy @ Adaptronic about it! He really hates the idea you need to change the CAS disc to run their ECU. Another alternative for you yankies/wrong hand drive countrymen is ECUMaster. Mark at MRC said they're great to work with and are good value.
https://www.sau.com.au/forums/topic/471951-aem-infinity/#findComment-7849407
I was under the impression that most aftermaket ECU's can't sample the data properly due to the way they're designed, in terms of the actual resolution of data side of things. (ie what a 24 tooth wheel in cas disc would be aimed at). Issues regarding moving it to the crank is another (related) thing entirely
https://www.sau.com.au/forums/topic/471951-aem-infinity/#findComment-7849559
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
