Need help losing oil but no oil leak?
Hey guys!
So ive got a r33 gtst.
Its got 180kms and im losing oil like crazy when i hit boost. Its stock besides fmic, exhuast and oil cooler. I noticed about a week ago my oil pressure has dropped but have done a major service 3 weeks a go. So i check the oil level and it was near empty.... looked around and couldnt find any oil droplets and/or puddles. Ive checked everywhere i park my car and no oil on the ground any where. But i did notice that the rear of my car get small oil marks (cars not running rich) . So i believe i have oil coming from the exhaust but dont know why. Please o wise ones share your knowledge with me! This is my dream car and i have owned it for 2months now and praying i did not buy a lemon :(
Did you do the service yourself? Fill the oil exactly to the mark on the dipstick?
Fill it again today and monitor the level for a week or two. If it has burned off a couple of litres do a compression test and then repeat it with a shot of oil in each cylinder to  see if its the rings.
Nah didnt do it myself had my mechanic do it.
Yeah ill get a compression test tomorrow or wednesday and post results
Few questions that might get you some better answers....
1-  any smoke at all under boost? Or any smoke under any driving conditions?
2- how much oil is your engine using?
For example if you dropped the oil now and put 5 litres in.  How much oil would you have left if you dropped it after say 500km of driving.
3-   what oil are you using now?
4- any leaks around your sump area or underneath engine that you can see? Wet looking spots....
5- i like cats, would this shirt make me look gay at powercruise.
  • Like 2
Can you give me an answer for both if i said yes and no? Because i havent seen any smoke but then again never had someone stand behind my car and tell me.
So 3-4weeks is almost empty.
10w 40. My dad told me to get maybe thicker oil cause the cars done 180kms but not sure?
Doubt it because only park in the same 3 spots everyday and no drops or anything on the floor.
f**kkk no! Get me one! f**k dat gucci shit get me one of those and ill wouldnt give two f**ks about mi car :P
3-4 weeks of driving and its chewed through 3-4 litres of oil doesnt sound good.
Im not a mechanic, im not going to tell you whats wrong. Maybe someone on here will steer you in the right direction. My amateur mechanic guess is oil is going past your rings and being burned up.
Or you have a serious leak that you really havent found. Do you park on grass? Or where there are rocks? So you wouldnt really see a oil spill. Just saying,  might be something very easy to fix or something expensive.
Edited by Cyko34
So have you topped up the oil or are driving around not knowing how much oil is in the sump?  If not buy some oil and drop 2L in, dip it , and then add 250ml at a time so you know how much you are under the full mark. It sounds as though you have limited mechanical knowledge and are using a workshop for everything which is sensible but in order to save money and learn to have confidence in your car it is good to start doing the basics (oil change, plugs etc) yourself.
2 hours ago, MrR33SKI said:
Dam im hoping its just the turbo?
But how much would i be looking at for piston rings?
$200
The bottom end build to install them though...
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
