12 hours ago, MrR33SKI said:
Turbo lol. Ive gone with a rb26dett for the 33 gtst. Cbf for the head aches of having someone elses thrashed motor lol. Ill see what i hit on the dyno and post pics here. Thanks for all the help guys
Umm yeah, that's like saying you hate guns then buying an AK-47.
Boggles my mind how people think the 26 is much of an upgrade over the 25. Older engine design with more flaws; GTR taxed parts and less availability; more prone to catastrophic failure...all for a negligible increase in displacement and a different soundtrack.
  • Like 3
Don't forget them all being thrashed.
At least the RB25DET has a better chance of being less thrashed, especially if it's from an auto car (e.g. Stagea).
And that the newest engine you'll get is already 15 years old, a lot if people dont even realise that some of our favourite cars like the r32 gtr are already 27 ish years old!!!
God damn dinosaurs
Edited by Cyko34
  • Like 1
Constantly trips me out that my R33 daily is older now than VH Commodores were when I first got my licence...I thought VNs were old shitters back then lol (they were)
Car is running perfect now. No issues st all besides having stock power. Have had a long think about it and came to the thought of just keeping the car stock and healthy. Also i have decided i would like to get a s15, evo7, and/or supra for a weekend car and keep the skyline as my daily.
This might sound stupid but if your burning through lots of oil check your PCV valve is working correctly
I’ve recently gone through a similar exercise with my Dads landcruiser which was using about a litre per 1000km
It’s done 305,000kms so we thought it was just worn rings. However I decided to pull out the PCV valve to check it, and it was stuck open. The vacuum hose going to it had split, so it didn’t have enough vacuum to open and close it and it got stuck
Cleaned it out with some solvent, put a new hose on and it’s using bugger all oil now, running sweet
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
