You are correct to a certain extent. I only did the service there because i needed the rocker cover gaskets replaced and head cleaned and little things here and there.
How much am i looking at for the piston rings to be replaced? Also would it be cheaper to just pop in a new engine. I can get a rb25det for 3k supply and fitted.
20yrs ago wow...has the engine been started in that period? If not, the engine will more than likely require a rebuild. Rings will be dry, valve stem seals dry and deteriorated etc.
What did you read? Im going crazy.....
  • Like 1
