RB25Neo/30
A bit stuck, done a search but just confusing the f**k out of me.
Got an RB25Neo/30 in my R32. Using the rb20 loom, got a coil conversion loom and rewired the injectors.
When it comes to the ECU, what can I actually run? From what I have worked out there is a GTRLink that I can use as it's the same ecu plug.
Found a Vipec V88 for a neo, that won't plug in though will it? How do I get around this as it's a good price.
cheers.
https://www.sau.com.au/forums/topic/471974-rb25neo30/
Hi mate
you only have 2 sort of easy choices here.
1. Remove the loom, and install a RB25 NEO loom to run with the Neo Vipec.
2. Get a GTRLink / Vipec. These fit all GTR models, and the R32 and R33 GTS-T.
Any other way will only be a huge bitch.
You could get yourself a brand new wiring specialties Neo harness. Would cost about $1k but then you have a new loom.
Personally, since later model Neos have fairly new looms in then, just grab a factory one of those nice and cheap
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849159
1 hour ago, The Mafia said:
Hi mate
When you say get a GTRLink/Vipec which Vipec is this that will work?
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849175
Vipec and Link are the same thing / same hardware. Vipec is actually gone now, absorbed back into Link.
Vipec "V" series = Link G4
Vipec "i" series = Link G4+
You want the model of vipec or link that fits the GTR. It also fits the RB20. (It's a one ECU fits all)
The GTRLink / GTRVipec fits everything except for the Neo as that has a different plug.
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849180
Damn this one fits a neo, that's a no go.
Thanks heaps mate.
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849182
There is no RB25 Nistune so if you have an RB20 Nistune that will work although it will not control your VCT.
If you get a Neo ecu and loom you can get a GTT  LinkECU to put inside the Neo case which would be ideal...it can control your VCT and with a solenoid better control boost.
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849434
10 hours ago, Griffin said:
I have the same dilemma with a rb20de cefiro. It's auto and I want to keep it auto. Can I use a link rb26rb20 plugin? Do they have a built-in map sensor to do away with afm?
I don't know where the auto ecu is on your cefiro. If it is in the main engine ecu then no you will not be able to use the GTR Link. Why don't you get a wire in Link instead and yes you can use a map sensor with it.
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849627
Do you know how to find out? Will it be in the same location behind kick panel where main ecu is?
I have an rb25 det manual loom and ECU, should I fit that and get a manual valve body for the auto to do away with the auto electrics? Then I could fit a plugin ECU .
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7849638
  • 3 weeks later...
I'm running a 2530 neo in my r32 gts4, basically had to do a small amount of soldering for tps and idle valve and coil harness. Add in a wire for vct
Can use pretty much any plug in ecu for r33 r32 gtst or gtr. Some need an injector pin swaped around and if using GTr or 32 gtst ecu need a way to control vct, so rpm window switch or if using an r32 gtst nistune then use the feature pack and it let's you control it like stock
I use an adaptronic select on mine personally.
https://www.sau.com.au/forums/topic/471974-rb25neo30/#findComment-7852430
    • Where did you get the test done? What did it cost? Can you just book an appointment? And I presume it's independent so failing would not mean suddenly having an unregisterable car? I would like to make some exhaust changes on my car and would love to get before and after results to see how much of a difference it makes. If it's in Botany even better as that is pretty much local.
    • Sorry solder been off line for a bit, still lots to move on too with the r31.  yeah the wiper motor is a go for sure.  wow September that’s pretty rude, do you think the interior loom is much different to mine? Of course I would need to swap the clock also as mine has a trip computer that doesn’t work haha
    • Just got back from a week away out west, and it seems the R31 forum isn't responding ~ I know there's a lot of AI/bot scraping causing problems on da'net at the moment, so dunno what's going on. I'm actually more concerned about another member on there, I've been trying to help rebuild his automatic box... no idea where he's up to in the build, frustrating, a bit it is.... Anyone got any news?
    • @GTSBoy Wouldn't you just prefer to have a modern dash though?  Even if you could wave a magic wand and have the fancy gauge cluster your describing, a modern dash would do a million more things and do a better job of it.
    • Howdy ~ got that wiper motor out, all good ....also, replied to your post in the R31forum wrt ashtray and rails ...but I've been away for a week, and getting home, that site's not responding, so posting here for FYI... ...also, our mate sold this place last week (that was a surprise to come home to), so we've got until Sept. or so to move out ~ needless to say, if you want any other bits off that R31 pinny donor, now's the time to claim them 😃 Good to see that carpet piece finding a home...that was a bit of a score 😎
