Hmmm, reading into them tonight, might not be what I'm chasing.......
Luckily I was pulling them back off either way.
Still have the 7s to use.
But, I was hoping for a little more.
Why not just keep the 7s and see what they make on e85, then race it like that to work out all the problems and if the cars not doing the times you want then you can look at something else.
Just get it running right before you worry about making 450kw
-9's won't get anywhere near 450 mate.
-7/-9 are close enough to each other they're not worth discussing the differences really.
Original goal was 400.
That would be terrific for track work I reckon.
JEM reckon my car will make 350ish when i go back to E85, after i fix a couple of issues (that i told you about the other day Luke)
Realistically if you want 400 -9's will struggle as well...you'll either need -5's or a nice single. considering a precision turbo is cheaper than -5's id just do that, get someone to fab you a manifold.
In saying that i'm weighing up my options for my next turbo, because im a stubborn flamin mongrel and a but of a "purist" ill be sticking with 2 turbos....
If the motor is healthy you should be able to push around 350kw on E85 with the -7's. Spend the extra cash on the diffs, and enjoy.
350-400KW, Quaife front Diff, modified transfer case, nismo rear diff=ultimate street car IMO
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
