  • Replies 123
Looks like you could have a good turn out George,,,,,Count us in,,,We'll bring the Mascot....
Shell if you get in to Sydney early,,,drop me a line
0419 160561,,,we're on Holidays,,,could meet up with you and George,,,do some arvo coffee/food or something.
Neil.
yeah looking good neil. can't wait to see your horse... i mean monty again. i've taken the day off & i have to go pick up ryan around lunch time so i'll be around pretty much all day. i'm up for anything so...
hey, i told you i'm changing sides. st george is a sad team these days. good win over the broncos though.
Everyone, if you can't meet at the right time or get lost or whatever, my number is 0438 438 567
George
Neil.
Will do, Neil! ;)
I doubt it will be before about 4pm tho, cos I'm not planning on leaving here till around lunchtime.
NDR Wrote :
Hey ONARUN,,,I'll let you in a little secret,,,,when you get Married ,,,She becomes the BOSS. It's not a bad thing,,,just as long as YOU have trained her well.
Thats what I call hitting the nail on the head, so true, so true.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
