R32 GTR Shuts off driving
I'm having an issue with my '89 R32 GTR. Twice now it has shut off completely while driving and after about 25 or 30 minutes it will finally start up again. This has happened after taking a hard pull and then coasting with the clutch pushed in. After pushing in the clutch the rpms blip a thousand or so and then go down to normal and then a mile or so down the road the car just shuts off. I can continually try to start the car and it will try to turn over but won't start until about 25 or 30 minutes later it will just start up. After it happens the car drives normal and reaches full boost and full power no problem. It was about a week or so between the 2 issues. Originally I thought it was an issue with the alternator which was found to be bad, so that was replaced with an upgraded Nissan Quest unit. Even with the boost turned all the way down on the ebc, it will fluctuate between 19psi and about 21psi. Is that normal to not have a dead on reading all the time? It was at 20.8 psi when it shut off the last time.
It is frustrating because I was doing hard pulls earlier and had no issues. I had done hard pulls in the week or so between the 2 instances and didn't have a problem. If anyone have any suggestions I'd appreciate it.
Car has:
HKS GTIII SS turbos
Tomei Expreme Outlet Pipe
HKS Front Pipe
R33 Catalytic Converter
HKS Silent Hi-Power Exhaust
Apexi Power Intake Kit
Nismo Fuel Pump with rewire
Injector Dynamics 725cc Injectors
R34 Coilpacks and conversion on Wiring Specialties harness to remove Ignition Module
Link ECU using built in map sensor with mafs disabled, o2 sensor removed and tuned for wideband
HKS Vcam
HKS 264 Exhaust Camshaft
Greddy Profec B EBC
https://www.sau.com.au/forums/topic/472057-r32-gtr-shuts-off-driving/
Awesome thanks. I will try and test the CAS.
Any suggestions on the boost issue? Is it possible the turbos are flowing too well with less restrictions in the exhaust, causing an increase in the boost? The shop I have work on it say that it's dead on 19 psi on the dyno and that it isn't a boost leak but on the street it goes over 19 psi.
I had an AEM boost solenoid being controlled by the link but with the boost issues it was hitting boost cut and I thought it was easier to be able to make adjustments on my own with the profec instead of a laptop with software I didn't understand. As soon as the boost issues are resolved I plan on going back to the link controlling the boost though. Also I wasn't sure if the link was originally having issues controlling the Vcam and the boost at the same time with it spooling so quickly.
Thank you for the graph. That looks pretty smooth on your boost. I think I have gotten my boost issue figured out. The first shop I had work on it forgot to remove the brass pill from the line so now that it's gone it only fluctuates between 1.21 bar and 1.32 bar. Now just waiting to see if the cas issue is fixed.
  • 3 years later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
