Hi guys recently had my coils changed over to yaris coils and i had a miss under mid boost running 19psi on full so at about 14psi it breaks down. I checked the plugs and they were gapped at .6
Should i change them to .8 or is there something im missing.
https://www.sau.com.au/forums/topic/472058-spark-plug-gap/
My yaris coil kit from golbey parts (not sure if genuine coils or not) has run 23psi on the standard bcpr7es gap, think its around 0.9 from memory..  I suggest you check wiring/earthing, or as above the coils could be old or faulty
https://www.sau.com.au/forums/topic/472058-spark-plug-gap/#findComment-7850225
They were brand new from golebys as for dwell im not sure as i had a mechanic install the setup. So i should regap the plugs back to .8
I just thought with new coils i shouldnt be runing such a small gap.
Ill check what dwell im running when i get home this afternoon
https://www.sau.com.au/forums/topic/472058-spark-plug-gap/#findComment-7850228
