Hks turbo Identification
Hi guys.
i have a used hks turbo in my possession.
Chra tag states it's a 3076r chra
tag # 700177-5007S
i have not seen a 3037 with this front cover, only a 2835 pro. anyone else have this Comp cover on their 3037?
Rear housing is a .7 t3 hks dump pattern.
any help greatly appreciated
https://www.sau.com.au/forums/topic/472066-hks-turbo-identification/
That will almost certainly be a HKS GT3037 Pro S , assuming it hasn't been interfered with . They look virtually the same as a GT"2835" Pro S except the turbine and compressor are larger in diameter . GT3037 is HKS speak for what Garrett calls a GT3076R in 56 compressor trim . Pro S is for their unique compressor and turbine housings .
The turbine exducer or outlet diameter should be around 55mm .
Cheers A .
Cheers A .
Thanks for the response disco. Was hoping you would chime in.
This turbo capable of 350ish rwkw with a .82 rear, on a neo with 85 on board, all in ?
HKS did GT Pro S turbine housings in 0.68 and 0.87 AR sizes . I'm not sure if the 0.68 AR one would get 350 RWKW especially on PULP .
In theory you should be able to use a Garrett T3 flanged IW turbine housing on that unit and most opt for the 0.82 AR size on RB25 turbo engines . Those Pro S turbine housings were gold in the days before Garrett were making integral waste gate housings of their own - which are same format as the Ford XR6T T3 IW turbine housings .
A .
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
