Modified r34 gtt part out
due to repair damage quote being a lot more then planned. i will be parting out my r34 gtt
car has all parts at the moment except front bumper passenger side skirt and passenger rear pod, both tail lights.
car is located in geelong and still drives on its own.
engine has 226,xxxkm all mods are less then 60k km runs fine no damage to anything mechanical just quater and end damage
quick mod list:
walbro 460lph fuel pump: $160
splitfire coilpacks: $300
tomei poncams type b: $600
bosch 100amp alternator: $120
ev14 725cc injectors: $500
 turbosmart hypergate 45mm external wastegate: $300
apexi avcr boost controller:  $400
plazmaman intercooler with cusom pipework (done by havoc fab will bolt onto standard pipework): $800
hypergear atr43ss2 turbo changed to V band external gate (2014 model and journal bearing ~50k km old): $900
nistune with flex fuel tune: $700
z32 afm: $150
full custom turbo back v band 3.5" stainless steal exhaust with magnaflow highflow cat (done by havoc fab) $1200
custom external wastegate off standard turbo manifold (done by havoc fab): $300
BC coilovers (no knocks or leaks): $800
npc 10" sprung button clutch: $500
hicas lockout bar: $70
work xd9 18x9 +30(front) 18x10 +38 (rear): $1400 (will no split set)
nismo clear indicators front and side: F: $100 S:$50
boost, oil temp, water temp gauges: $150 for lot
and all other parts avalible
buyer pays shipping on parts. pick up is fine also
first in first servered. no holds without deposit
will provide photos app on request. prices are negotiable.
happy to split parts (except wheels) or do deals on multiple parts.
if parts are not stated as sold, they could still avalible please feel free to ask.
please message me on 0431394082 or reply here or pm. wont always be able to answer calls.
  • Like 1
https://www.sau.com.au/forums/topic/472073-modified-r34-gtt-part-out/
Oh, it's OK.  I'd only be interested in the diff if it was fully sick Nismo 1.5 way hella spec stuff anyway.  Hence my question about the subframe.  Because if I was going to change from my S15 helical, then I'd need driveshafts.  And if I need driveshafts, then I could use his.  And if I get all that, then he might as well put the whole rear end on a pallet and send it to me and I'll transplant yet another rear subframe into my car and get improved late model geometry (which I should have done using an S14 subframe instead of a Cefiro one!!!farken!).  After all, it's only money.  And then if I have R34 rear brakes I might as well put R34 fronts on as well.
See how it all snowballs out of control?
:D
standard gtt brakes. the whole rear sub and drive line is still in tact, as for diff im hoping to have it out today or tomorrow around work :) will get back to yous
took an ass raping by a grass bank... bloody vic roads and their horrible pothole written uneven roads -.-
ive had a lot of interest for selling the car as is, for those who maybe interested. the car is NOT a statutory write off, it is still able to be rego'ed (after repairs). i just dont have the money to repair the damaged myself.
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
