KiwiRS4T Posted May 28, 2019 Share Posted May 28, 2019 The Stillen kit is a proven unit and produces about 300 - 320 kw so no built engine required. It is apparently a relatively easy job to do at home and all you would need on top is probably a better clutch. It comes with a standard map or a tuneable chip (probably better) so if the latter budget for a tune. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906481 Share on other sites More sharing options...
shadow85 Posted May 28, 2019 Share Posted May 28, 2019 I know several people in Australia who went the stillen route. But with the stock original stillen kit you will only get around 280kw, and the stock kit is very bad in design and dangerous for your motor. Just do some research on it. If you want to make 300-320kw on the stillen kit you have to switch to A2A setup which there kits available for you to convert the Stillen to A2A. Then and only then will you have a chance at 300-320kw. And ontop of that, there is alot of issues with the reliability of having the kit operate as such. I know more than 2 people in Australia who went that route and all the trouble with it. One of them has already ditched the Stillen + A2A upgrade for a turbo kit all together. Oh and if you want to know how much better a turbo kit is than the stillen supercharger, just read here aswell: https://specialtyz.com/blog/?p=2887 But if you want to keep costs down to minimum and want the ease of install, and do not care about expanding power further then for sure go the Supercharger route. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906511 Share on other sites More sharing options...
wizlb Posted May 28, 2019 Share Posted May 28, 2019 A guy on FB Infiniti Australia Q60... using E85 produced these numbers Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906526 Share on other sites More sharing options...
shadow85 Posted May 29, 2019 Share Posted May 29, 2019 5 hours ago, wizlb said: A guy on FB Infiniti Australia Q60... using E85 produced these numbers Very nice, is that with the VQ37 or the new VR30DETT infiniti Q60? Is it Stillen+A2A kit or is that with a turbo kit? Could you give me a link to it, I would love to see more deets, where he had it built/tuned etc. Thank you. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906552 Share on other sites More sharing options...
KiwiRS4T Posted May 29, 2019 Share Posted May 29, 2019 20 hours ago, shadow85 said: I know several people in Australia who went the stillen route. But with the stock original stillen kit you will only get around 280kw, and the stock kit is very bad in design and dangerous for your motor. Just do some research on it. If you want to make 300-320kw on the stillen kit you have to switch to A2A setup which there kits available for you to convert the Stillen to A2A. Then and only then will you have a chance at 300-320kw. And ontop of that, there is alot of issues with the reliability of having the kit operate as such. I know more than 2 people in Australia who went that route and all the trouble with it. One of them has already ditched the Stillen + A2A upgrade for a turbo kit all together. Oh and if you want to know how much better a turbo kit is than the stillen supercharger, just read here aswell: https://specialtyz.com/blog/?p=2887 But if you want to keep costs down to minimum and want the ease of install, and do not care about expanding power further then for sure go the Supercharger route. Your link doesn't tell us anything about the TT set up. No-one doubts that a good TT system will produce good performance - the challenge is getting it in the space available and for a competitive price. The supercharger option already is not cheap - how much is the TT option and do you have any pics? Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906567 Share on other sites More sharing options...
wizlb Posted May 29, 2019 Share Posted May 29, 2019 Hey Shadow ... It’s the new Q60 and I believe it’s a red sport ... Kiwi, I will get those specs for you.. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906568 Share on other sites More sharing options...
shadow85 Posted May 29, 2019 Share Posted May 29, 2019 3 hours ago, wizlb said: Hey Shadow ... It’s the new Q60 and I believe it’s a red sport ... Kiwi, I will get those specs for you.. Well the new Q60 RS is a different motor all together. Uses a VR30DETT engine, they moved away from the VQ37. Unfortunately Nissan has not adopted that engine yet in any of their veichles although SEMA has converted one of their Nissan 370Zs to this new VR motor. 3 hours ago, KiwiRS4T said: Your link doesn't tell us anything about the TT set up. No-one doubts that a good TT system will produce good performance - the challenge is getting it in the space available and for a competitive price. The supercharger option already is not cheap - how much is the TT option and do you have any pics? TT setup is not cheap at all. If you go via the RevZone or CRD package, they have a walk in walk out price of roughly $16K. But that does not include any supporting mods, you want reliability and safety you will be adding, oil coolers, exhaust system, fuel system, injectors/pump, maybe upgrade radiator, clutch if manual, trans cooler if auto. Possibly alot more like I did. SC is much cheaper, but not as potent as the TT builds going around. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906588 Share on other sites More sharing options...
shadow85 Posted May 29, 2019 Share Posted May 29, 2019 9 hours ago, shadow85 said: Very nice, is that with the VQ37 or the new VR30DETT infiniti Q60? Is it Stillen+A2A kit or is that with a turbo kit? Could you give me a link to it, I would love to see more deets, where he had it built/tuned etc. Thank you. Can you link me to this infinit fb group please? Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7906589 Share on other sites More sharing options...
wizlb Posted June 4, 2019 Share Posted June 4, 2019 If you want to save some money, I still get a high-performance car, buy the Infiniti Q60 sports 300 and just adding these mods will push the car past 450 at the wheels .. CAI, LDP 2.5 or 3 exhaust Hear exchanger Ecutek tune!!! https://www.facebook.com/groups/1446645935357503/?ref=share Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907257 Share on other sites More sharing options...
KiwiRS4T Posted June 4, 2019 Share Posted June 4, 2019 51 minutes ago, wizlb said: If you want to save some money, I still get a high-performance car, buy the Infiniti Q60 sports 300 and just adding these mods will push the car past 450 at the wheels .. CAI, LDP 2.5 or 3 exhaust Hear exchanger Ecutek tune!!! https://www.facebook.com/groups/1446645935357503/?ref=share I don't facebook. That car is a twin turbo V6 which is a long way away (in dollars as well as anything else) from a VQ35de. And as we all know its easy to make more power from a turbo-ed engine. The initial challenge was to get more from an n/a 3.5 engine at a low cost. Not sure where the money saving bit comes in??? 1 Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907266 Share on other sites More sharing options...
niZmO_Man Posted June 5, 2019 Share Posted June 5, 2019 Isn't the engine VR30DETT? As in, smaller GT-R engine. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907348 Share on other sites More sharing options...
DashyyPC Posted June 5, 2019 Share Posted June 5, 2019 3 hours ago, niZmO_Man said: Isn't the engine VR30DETT? As in, smaller GT-R engine. Yeah they run the VR30DDTT. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907375 Share on other sites More sharing options...
370GTCOUPE Posted June 10, 2019 Share Posted June 10, 2019 for this power level, might as well just do NA bolt ons.. oh and if you want more.. nitrous Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907762 Share on other sites More sharing options...
mycarhasposessedme Posted June 10, 2019 Share Posted June 10, 2019 9 minutes ago, 370GTCOUPE said: for this power level, might as well just do NA bolt ons.. oh and if you want more.. nitrous Define "this power level"? Nitrous on the street, bit to much F & F I think. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907763 Share on other sites More sharing options...
370GTCOUPE Posted June 10, 2019 Share Posted June 10, 2019 8 minutes ago, mycarhasposessedme said: Define "this power level"? Nitrous on the street, bit to much F & F I think. title specifies 450hp, assuming flywheel Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907765 Share on other sites More sharing options...
mycarhasposessedme Posted June 10, 2019 Share Posted June 10, 2019 Big assumption there Champ, be a pretty pissy turbo kit doing 450 at the flywheel. Even so, NA guys are only getting around 320 ATW on a Dyno Jet in the US & that's with long tubes & all the Fruit, etc. If you assume a 20% loss, so 450 - 90 = 360. Still, thats 40 hp more than so called bolt ons will get you. Getting that power NA is not cheap either. Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907768 Share on other sites More sharing options...
370GTCOUPE Posted June 10, 2019 Share Posted June 10, 2019 26 minutes ago, mycarhasposessedme said: Big assumption there Champ, be a pretty pissy turbo kit doing 450 at the flywheel. Even so, NA guys are only getting around 320 ATW on a Dyno Jet in the US & that's with long tubes & all the Fruit, etc. If you assume a 20% loss, so 450 - 90 = 360. Still, thats 40 hp more than so called bolt ons will get you. Getting that power NA is not cheap either. whats with all the anger? Nitrous is a great option even for the street, the only downside is having to fill the bottles really. i would expect that kind of power for how cheap he is trying to do it for, low boost etc Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907773 Share on other sites More sharing options...
mycarhasposessedme Posted June 10, 2019 Share Posted June 10, 2019 No anger here Mate, sorry, did questioning your statement hurt your Feewings. So which Aussie State is Nitrous legal on the street again? Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907775 Share on other sites More sharing options...
The Bogan Posted June 10, 2019 Share Posted June 10, 2019 Who does legal? Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907784 Share on other sites More sharing options...
wizlb Posted June 10, 2019 Share Posted June 10, 2019 Q60RS.... add a few bolt ons and you are at 450 at the wheels ... plus you get a new car too ... Link to comment https://www.sau.com.au/forums/topic/472110-designing-an-entry-turbo-kit-for-v36-450hp/page/2/#findComment-7907785 Share on other sites More sharing options...
