Subframe bush issues
Hi All,
I just noticed an issue with my subframe a few months after installing it (i'm led to believe its been like this since installed) - When I jacked up the diff the subframe moved upwards to the body revealing a 10mm gap between the bushing and the bolt at all 4 corners. If I lower the diff while the car is on stands you can see the subframe hangs with the same gap but up the top.
The bushings used are Superpro ones and there are no lock collars installed. I'm not sure if I'm missing something but surely there shouldn't be this gap. For what it's worth this is an R33 GTST and I know someone with an R32 GTST with the same problem.
Can anyone please help me work out why this is like this? I've put some pics below to help show what I mean
https://www.sau.com.au/forums/topic/472130-subframe-bush-issues/
That's strange. Only thing I can think of is wrong size bushings?
I chucked sub-frame collars into my R33 yesterday and there was no gap with the stock bushings before putting them in (and of course none after :P )
  • Thanks 1
wait, you have removed stock subframe bushes completely, or using the pineapple-type inserts? From the pics looks like you're using full replacement bushes.
It's a few years back now but from what I recall, there were differing designs, and I went with whiteline bushes instead of superpro, I think for what you're experiencing now - they list them for r33 but they're based off r32 or 300zx or something, and don't fit as flush as they should.
I have a gap now, and did even with stock subframe bushes/superpro pineapple rings, but it doesn't move up/down with jacked up, the gap is fixed in position. If yours moves up and down even with the 4x nuts still one tight, that's a bit of a worry. Was the crush tube the same length as the bush it slides into, or longer?
  • Thanks 1
Thanks for your replies guys, its complete subframe bushes. I put them in a few months back at my mates workshop.
Unfortunately I didn't think of measuring the crush tube but I would dare say that is the cause (nuts tight down)
I'm thinking of chucking the lock washer/collar in the bottom between the washer and the bush to push it hard against the body which should eliminate the gap. The part number was listed for a few different nissans so I would take a guess that you're right @hardsteppa
Thanks for your input guys, I might even call superpro in the morning and run it past them :D
  • 4 months later...
So an update on this, a mate with an R32 and the same issue called Superpro and they said we need their pineapple kit too KIT201K which is a PITA. Doesn't make sense that you should have to - nonetheless, I purchased and installed now the subframe sits normally again with no more subframe knocking.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
