Guys need some advice please I removed cam angle throttle position sensor to replace my water pump nd took off alternator belt now engine is not turning up don't know why. Belt on alternator looks misaligned apart from that I put on back each nut bolt the same way I took off . Now starter motor just winning. I got work tomorrow please need some help asap nd it's r33 rb25det by the way. Hope to hear you soon thanks
First, Cam angle sensor and throttle position sensor are 2 seperate things...
Amusing you only mean the CAS, since you did the water pump an belt, Did you mark the belt and cam gears before taking the belt off so that they're aligned correctly when you put the new belt back on? likewise with the CAS?
