M35 won't fire
Evening, sorry about the long post but I'm trying to give as much info as possible.
I have recently acquired a 2001 M35 stagea (VQ25DET), the morning after driving it home it it would turn over  but not fire, after 10 minutes of trying it finally fired up but ran like crap. Next few starts it started and ran well.
Saturday morning it started and drove fine. Come Saturday afternoon it wound over and over, after 20 minutes of trying it finally started, but ran terribly all the way home. Got it home and shut it off and tried to restart it and it just wouldn't fire. Sunday morning I tried and just keeps winding.
I have checked all the fuses, changed all the coils, the plugs, the immobiliser batteries and the CAS and it still won't fire, when turning over it will get the occasional cough but that's it. The cam sensors were changed with the recal but I'm not sure how long ago.
The car is running a Greddy Emanage and the MIL light is on all the time (owner said this and after searching it is a common thing with these ECU's)
I have tried the self diagnostic thing with the key and the pedal but for the life of me I can't get the MIL to flash, I've used a stop watch to time everything and still can't, no sure if just me or emanage has something to do with it
I don't have a scan tool and can't start the car to take it anywhere, does anyone have any ideas or suggestions on why it won't fire?
Edited by Coullsy
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/
May be flooded. I would check to see if you have spark. If it does, dry the plugs and try some start ya bastard. Something obviously isn't right considering it runs well then it doesn't. Do you have the software for the emu so you can see what's going on? There was someone over in Adelaide that is pretty knowledgeable with m35 and emu. I think its BoostdR.
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/#findComment-7851574
Ive attached a quick video of the spark, to me it looks weak, as I believe it's meant to be a bright blue, but that could be from the gal I had in the tester.
i did manage to finally get it to throw codes which came up with the following.
0100 - AFM
1320 - ignition signal
0110 - intake air temp sensor
1705 (I counted 1805, but could of counted wrong, will confirm)- Throttle position sensor circuit A/T
The 0100 AFM fault may be because I disconnected it and tried to start it to eliminate it. I will reset the codes and see what it throws up again.
Would the 0110 code be related to the above?
1320 code I don't know what it could be, as I've done the coils, plugs, CAS and rechecked all the plugs (possibly throwing the codes due to not resetting after changing them?)
Is it possible that the TPS is the issue that is preventing it from starting?
IMG_5996.MOV
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/#findComment-7851631
  • 4 months later...
So an update on this for those interested.
Turns out that the Emanage was dumping alot of fuel into the cylinders.
instead of dealing with the emanage, it was ripped out and now i have installed a Haltech Elite 2500. The car is together and has been tuned. Currently making a healthy 252AWKW.
https://www.sau.com.au/forums/topic/472151-m35-wont-fire/#findComment-7867880
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
