Amp & Sub have no idea
Hi guys , I know nothing about car audio and want to buy my son a subwoofer, he had this kicker 400.4 amp and wanting to know if this pioneer sub is   Compatible.
Thanks ken
  • 12 inch subwoofer
  • 1300 watts max music power
  • Sealed carpeted enclosure
  • 350 watts RMS at 4 ohm
  • Custom grille
https://www.sau.com.au/forums/topic/472156-amp-sub-have-no-idea/
is your son currently using the kicker amp for his car stereo?
if he is it may not have 2 spare channels to bridge for the sub.
If the amp has 2 channels spare then as @inmaniac says - bridge them
cheers
Mike
23 hours ago, Robzilla32 said:
I have a Pioneer TS-WX305B (previous model I assume) for sale if you live close to Melbourne. It is BNIB. $125.00
Up in Queensland rob bit far thanks
2 hours ago, mikel said:
LOL, clearly I don't buy enough stuff off the internet - I had to look up BNIB! ("Brand New In Box" for those like me)
Mike
in your diagram you're wiring 2 x 2ohm speakers in paralllel - that's a 1ohm load - my quick review of the amp says it can handle a 2 ohm load not 1 ohm.
Even at low volume, a 1ohm load could put the amp into protection mode due to the high current required with such a low impedance load
if the drivers were 4ohm each it would be ok
looks like you need 2 channel input, not 4, (your ? above) and get 3 channels out - left, right and bridged sub - left and right crossed to sub at 80Hz
cheers
Mike
Hey mike , would I be right in saying if my speakers are 4ohm I could wire up amp as in diagram , this wiring diagram is my preferred way but if I have to could  I bridge sub ,run front speakers from amp and rear speakers from head unit .
Thanks for all the help Ken
Hi Ken,
I'll preface this post with the point that most of my audio experience is with home and pro audio not car audio, but most I say below should still apply...
correct - if your speakers are 4ohm, then in parallel they (should) present a 2ohm load to the amp - and based on the quick skim I had of the amp specs this should be OK.
That said, a speaker's impedance varies with frequency - it has a peak impedance at the resonant frequency of the driver, then drops back and rises slowly as the inductance of the voicecoil increases with frequency.
Driver specs don't really provide enough information (eg 8 ohm vs 4 ohm) as to what their minimum impedance is, but it's a start.
"Normal" home/pro audio drivers are typically 8ohm or 4ohm - maybe some car audio drivers are specced at 2ohms - I wouldn't know.
In home audio and pro audio any speaker/driver that dips below 2ohms impedance would be regarded as a "difficult" load for any amplifier to drive.
You should never connect a load impedance to an amp lower than what the amp can drive - the output stage of the amp will go into protection mode (if you're lucky) or fail.
If your drivers are 4ohm, not 2ohm, start with the wiring diagram you provided - it should be fine.
If your drivers are 2 ohm (does car audio have 2ohm drivers?), then you could wire them in series as opposed to parellel and present a 4ohm load to the amp - this would be fine as far as not overloading the output stage of the amp, but may require tweaking of volumes on amp channels to get the balance right between mains and sub (which is required anyway if adding a new sub)
In reality you need the ability to change the volume front to rear (ignoring the sub for the moment) to get the balance right - so this is a good idea.
Running front and rear speakers in series or parallel won't allow volume tweaking front/rear.
Based on my (limited) knowledge of car setups, your front speakers are more important - so running the fronts off the amp and the rears off the head unit is the best approach - as you've suggested.
Whichever way you go you should plan around 2 channels bridged for the sub with the following points as suggestions:
  • the spec of the sub says 94dB at 1W (in car) - I suspect that 94db is measured at 60-80Hz or so, not 20 - 30Hz - hence you'll want the extra power from bridging 2 channels of the amp
  • for a bridged amp (2 amp channels in bridge mode), each amp channel "sees" half the speaker load, so for a 4ohm speaker connected to a pair of amps connected in bridged mode - each amp sees a 2 ohm load - make sure the amps can handle the load (in this case a 2 ohm load from a 4ohm speaker)
  • be very careful of EQ boost at low frequencies - in car audio you get significant cabin gain that works in your favour, but even with that, in the bottom end where the driver/box response is dropping off, adding EQ can consume available amplifier headroom very quickly and force the amp into clipping.
cheers
Mike
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
