2 hours ago, ActionDan said:
I can tell you now that when I build my new shed there will be no skids inside it lol
Now... what should I use to coat the floor...
How are you going to get the efames?
I've used the rustoleum coating in parts of the shed, seems to be holding up alright.
5 hours ago, ActionDan said:
Is that an epoxy thing? Epoxy looksl ike hard work to do well.
Last shed I just used a basic concrete sealer with a cerramic grit in it, that was "ok".
yeah epoxy, like anything its all in the prep. Biggest issue I had was the humidty that day stupid high and it dried quicker than I expected.
Prep was remove paint & grease, Citris scrub, water wash, etch, dry over night then coat. I haven't driven on it as other friends have had issues with it peeling parking car son it.
Yeah I'm not doing 140sq m of that...
Car moved under its power back to the big shed. Very happy with the wheels on it finally but will need to get 235/245 for the fronts.
With the sil80 now moved its allowed the 370 to be parked in the garage. Freshly ceramic coated and tint, still no plans to mod it
  • Like 3
Scrolled back and had a man look and couldn't see it..... did you repaint the wheels? if yes where did you get new RAYS stickers, and are they good quality? I just repainted my TE37 and need new stickers
I bought the wheels new when Import Monster got the last run of them.  They can source stickers & centre caps
53 minutes ago, Dose Pipe Sutututu said:
The Nismo Ed. front bar looks sick!
the whole kit is so much better than standard, it has confused a few people thinking its a gtr ?
Just without the box issues and weight 0_0
Yet I still want one for no good reason at all.
If it wasn't for the bland/old looking center console I would have a 2011-2014 one. The facelift 2017+ interior is so much better
23 hours ago, ActionDan said:
I'm talking R35s, are you?
Yep, have a look at the interior differences. When you spend 90% of the time driving a car the interior has to nice especially when spending over 100k
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
