Been chipping away at heaps of little things over the past few weeks. Pulled the Coilovers and lca out of the race car, cleaned up the Coilovers, new bush and ball joint for lca and got them in. Needed to make a small bracket to hold the brake lines.
Also fitted and wired up a new oil pressure/temp sensor and sorted fuel pressure with the old oil pressure sensor now reading it. Got a cheap Android double din wired up and have the link data showing on real dash app.
Cleaned up the te37 wheels and got them fitted with new wheel nuts. Then got it out for some quick pics.
Now all that's left is exhaust, new engine oil and filter, wheel alignment, washer reservoir and tune. Waiting on hoist to start exhaust so practicing stainless tig welding which has been harder than I thought it would be but found some good YouTube videos which have sorted out a few of my problems 😅
Use a proper gas lens with a large cup >10 and you'll be surprised at how much better again you'll get it.
Or if you feel like giving the credit card a run use the furick welding cups, even better again
  • Like 1
going to get a botle of gas tomorrow so will grab a 10 cup. Have looked at a a lens kit but see how I go with the big cup first.
  • Like 1
Got a lense kit and cup for the tig makes a difference just need to get more practice and a steadier hand.
Got the hoist up now, seriously if you have considered one get it been great so far.
Made a start on the exhaust today, started with a basic bracket for the cat, then cut up some bends and got it up nice and high with a magnaflow straight through then into the old twin tip muffler. Will add a vband at the diff, 2 new hangers and then weld it out.
Got a busy few weeks so won't be able to get much done but plan to get wheel alignment, tune and then have it fully detailed ready for sale around April.
  • Like 2
  • 1 month later...
Got the exhaust all done and it turned out ok. Got it up nice and high with plenty of clearance, painted it all black except for the mufflers and made up a tailshaft loop as MA regs requires one. Started with an aeroflow loop kit and modified it to suit.
Then sent the car off to the detailer and had it cleaned properly, got the interior wet cleaned also got the windows tinted.
154802858_2575421619421314_3416791332289965135_o.thumb.jpg.e2c5bab1c6d2894511f8091f62eaa4a9.jpg154366002_2575421626087980_1232864971140944989_o.thumb.jpg.59ce44c98f6d1168bd98de9693f21465.jpg
Next cleaned up a cusco strut brace I've had sitting around by powder coating the brackets black and polished the bar. Need some new bolts before fitting it.
IMG_20210224_172514.thumb.jpg.2480c266d8b5fdcba4fa6c72a232dbde.jpgIMG_20210224_182225.thumb.jpg.7f894bc17d035ab50f997ebf1d6dcc13.jpgIMG_20210224_185235.thumb.jpg.e6e89d878c1d674b7e9304ecbfefb563.jpg
Have now got a date to finish the car off as I've entered rockynats at Easter in the street drags, Dyno and cruise so now sorting out little things before rego and tune in a few weeks. Spent tonight fitting front wheel speed sensor and making a template for ducting to the oil cooler.
IMG_20210301_161219.thumb.jpg.fd98a6a6527139ec98e0df5f1b6c2e44.jpgIMG_20210301_191132.thumb.jpg.1e040853d9cb95815c01f2336cb6c56d.jpg
Tomorrow nights plan is to do a service with new oil, filter, coolant and plugs as it's been a long time since I did it. Biggest job I'm hoping to have sorted by rockynats is working aircon, I've got all the lines but going to put some heat sleeve over them and do o rings will be nice to have for cruising.
  • Like 3
Dry sump and Samsonas would have prevented that failure 😜
First proper service in almost 4 years, going to be using this Penn grade oil as a local parts shop is now sponsoring the race car for the year with free oils and filters for the cars.
Slowly been chipping away at little bits everyday at the moment. Flushed cooling system again as all gunk had turned coolant brown after a few heat cycles, refilled with Demineralised water and penrite red coolant but looks like it needs one more decent flush which I'll do after Dyno tune on the 16th.
Finally got the ethrottle 100% sorted with some help from Link, I didn't realise idle control table was an adder for ethrottle map so now cold/hot starts and idle is perfect.
Spent this afternoon sorting lines for the air conditioning. Gave them a quick clean. Required some light bending to use a mix of r33 and s13. Will replace the drier and o-rings before gassing it. Need to look at the climate control unit as stuck on heat and floor vents which is annoying.
IMG_20210308_170859.thumb.jpg.79168425a57979e88555045607d8da7a.jpgIMG_20210307_111738.thumb.jpg.90a6417fd555bcb2b2e7958f68b23b07.jpg
  • Like 2
5 hours ago, ActionDan said:
Aircon... Fancy man.
Minimum requirement for a street car for me now.
4 hours ago, Dose Pipe Sutututu said:
Future Classics we are hodling now, diamond hands baby.
I won't be holding onto this much longer hopefully it's going up for sale at rockynats. The 370 does everything this can do so much better I think.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
    • I know this is a super old topic, but what ended up being the problem?
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
