2 hours ago, GTofuS-T said:
Awesome update! I did the exotics racing F430 in May too!! (but last year) was good fun but over way too soon.
Do you have any further details on this setup? is it a product or DIY?
Here you go, its a little bit clunky at first but I wanted something more modern and pull data straight from the ecu. It also has a media control but need an external amp to power speakers
https://www.facebook.com/Raspexi/
43680878_1118724664968462_79459270651260
46468102_1143205335853728_22002123301327
  • Like 2
  • 1 month later...
2019 Updates :D
Sold my Monaro over the weekend :( but got to buy a Unimig 200Amp ac/dc tig and start making the intercooler pipes. First time welding aluminium and happy with it for now. Hot side is all welded and just need a 90 degree silicon, cold side is have cut the the first 2 bends up.
Also started doing a LS conversion in a mates vh commodore so my time is currently split between the 2 cars.
Hoping to finish pipe work & exhaust on the sil80 by Friday and going away over the long weekend so may program the ecu & start the car mid next week
  • Like 1
  • 4 weeks later...
Pipe work all done and engine now ready for coolant. Got lazy with the exhaust and bought a justjap cat back will finish fitting it tomorrow and waiting on the aluminium box for astra power steering set up then will fire up and start tuning next weekend
  • Like 2
Went to put coolant in last night to start it up and then there was a big puddle on the floor so gave up.
First thing this morning removed radiator and it had a crack where I had ground abit too much off to fit it better. A quick weld and refit it all and no more leaks ?
Put in a battery, plugged in the laptop and loaded a base file. Started testing injectors, igntion, set up e throttle & calibrated cas.
Hit the key and it spluttered to life but won't stay idling BUT it does start. Have organised to get some help sorting the tune.
Pretty happy that it at least starts and done everything myself this time around.
Will get a video once its running nicely
  • Like 3
Got the car idling well after rechecking a few things in the PCLink software and sorting out the wideband input
First time out of the shed in 18 months
Video of idle so much smoother with the DBW setup
  • Like 3
8 hours ago, Dose Pipe Sutututu said:
New SAU tradition, skids in Mexico
Will get rego after Japan holiday in May then a mexico trip will happen
Before I took it off the road around March/April 2017. This pad is in a local guys backyard
  • Like 3
Got it on the dyno tonight and didn't all go to plan
End result was 227kw on 14psi no matter what we did. Wastegate spring is too soft (7psi) & leaking at manifold flange, catalytic converter may have collapsed and fuel may be off (tried mixing half a tank with old & fresh). Got a few small water & oil leaks.
Plan is to get a gate spring tomorrow, drop the cat out with decat pipe, reseat wastegate, fix all the leaks, drain fuel and double check base timing.
Got 2 other cars to get ready for racing & setup the race event this weekend so will try and get back on the dyno next week
Also bought a dedicated circuit/drift car
Sr20, gt30 T2 flange, Link g4+ plugin, coilovers.
was a great deal so couldn't pass it up. Plan is to do all new suspension, r33 brakes, add some sensors to engine (IAT, Oil Pres & temp, Fuel Pres & temp and a flex sensor), fixed back seat and a big tidy up. Need to bin the kebab spec dual sub setup too.
  • Like 1
Haha we have very similar tastes. I have an RB20 S15 street car and just picked up a basic SR20 drift car same as yours.
I bought a G4+ plugin for it and adding Oil pressure/temp, Coolant pressure/temp, Fuel pressure/temp, Manifold air pressure/temp and flex fuel sensor. Can throw up some pics of how i did it all if you want, was a bit of dicking around but well worth it imo.
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
