19 minutes ago, TimmyMA70 said:
I love a good DIY build mate. Can't wait to see the finished product.
Yeah I have found it is easier to do everything myself as haven't got any where up here I trust to do the job properly.
All going to plan should all be together next weekend. Should look good and be a good reliable car.
  • Like 2
If there was ever someone who gets it, it's me man. I don't trust other shops either.
However I think it's far more rewarding once the project is complete ?
  • Like 1
2 hours ago, ActionDan said:
What major issues are you running into painting it? dust? runs?
Colour looks nice.
orange peel and not enough coverage in spots. Already had a mate suggest rub it all back and give it another coat with all the panels and kit on as i have had to paint the shell and kit seperate. Also trying to paint in a 3m wide space & poor lighting isn't a good idea.
On 7/10/2019 at 10:14 AM, ActionDan said:
Yeah a rub back and another coat won't hurt, especially if you're already set up to do it now.
Never gonne come out like a pro on your first go, kudos for having a go.
On 7/10/2019 at 10:36 AM, admS15 said:
X3 for rub back and another coat
When i get a break between a few events or have another off I go over the whole thing again.
Finished painting everything but didn't redo the body as racing more importanter with the next hill climb on next weekend.
Just need to fit harness, put in proper coolant, wheel align and clean under the bonnet
3 hours ago, ActionDan said:
Looks decent, still sad you didn't go for it while it was all setup and reay to go.
Now you are a pro come do mine thanks.
Came down to time and motivation. Rather be driving than building at the moment.
Lol, far too cold where you live for me. Have a go but would recommend practicing on spare panels before doing the car.
2 hours ago, iruvyouskyrine said:
Looks decent for DIY. I'm thinking of painting my track car also, could you give a rough run down of what you did and cost of materials? cheers
Good from far, far from good. The front end, rear bumper & wing look heaps better than the body.
Sanded down with 320-400 with an orbital and did all the bog. Undercoated then sanded some parts again to fix high & low spots and another undercoat then 800 wet rub then colour. If you have the time and most of the equipment like a decent compressor definitely have  a go. I had to buy a spray gun $100 came with 3 different nozzle sizes 1.4, 1.8 & 2.4mm, sandpaper & paint as i already have a decent airsystem with a 2.5hp compresor, 200L receiver, driers & filters and air hoses. All up so far for paint and material around $900-1000 which was a 3rd of the price local shops wanted for a closed door respray.
48 minutes ago, ActionDan said:
I happen to know a good spray painter, he will charge me less and do a better job lol
I only want white so I can sticker up
go something bright and wild to stand out far too many white or black "race cars"
On 7/19/2019 at 12:20 PM, ActionDan said:
Kinda want something simple like this.
Related image
That looks good, very factory looking.
Post Hill climb update:
Car went well and I ended up 3rd in class and I think 7 or 8th outright in a field of 30.
Tyres took  a few runs to scrub in and to get the pressures right as its a standing start and no warm up. Fastest on the day was a R32 GTR with 500kw doing a 55 seconds. Finished up with a 1:06:86 which is around 2-3 secs off the Sil80.
Cars steering feels light and took a while to get use to until I had some heat in the tyres. Tune needs a look at as had a few problems going back to 100% after a gear change. No leaks or damage so stoked about that. Going to add IAT sensor, move boost & afr gauges, wire a clutch switch and 2 other switches for a few things over the weekend.
Then off to Brisbane for a dyno tuning course and round 4 of Qld time attack at QR the end of next week.
27 minutes ago, ActionDan said:
Yeah that's why I like it, still race car bit clean and subtle.
Sounds like you had a good event, well done.
Clutch switch? For ignition cut flat shifting or something?
Yeah and launch control. Want to start using more of the ecu features.
Just standard Sr won't be proper flat shift but will set up ecu to cut ignition when clutch is engaged.
More setting up for launch control as majority of racing I do is standing start.
Would love a sequential box, maybe one day if I ever built a proper race car and had a race track and workshop support locally.
A Sequential would be amazing, but when a rebuilt/fresh Z32 with adapter/clutch is like a 5k kit or so, a sequential, at like 8k minimum for a 4spd or so, plus the extra's it really adds up.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
