Hey guys,
After some input.
Basically I've just sold my cefiro I'd built over the last 6 years. Built as a street car that I could take drifting. RB20, 240rwkw, laggy. No air con, loud, etc etc.
Maybe my age is catching up with me, haha, but didn't really enjoy it much lately, hence the sale.
I'd planned to replace it with a R34 sedan, keep the aircon, and just do the basics, (coil overs, diff, basic engine power mods for around 200rwkw).
My "daily" at the current time is a 97 series 2 R33 sedan, turbo auto.
Never really that into it, bought it off a mate when we needed a new run around, basically stock. Goes ok, but on the standard struts (with lowering springs) was never that inspiring to drive.
Popped that up for sale, and started looking for a R34.
Test drove one, and this is where I started getting confused. I think I may have had it in my head that  R34 would be noticeably better than our 33, well, the one I drove was not! Ha. Interior was a bit nicer, but no more room (less in the rear seats) than the 33. Chassis wise it felt very similar, and even power was no noticeable difference. TBH I think the r34 I drove wasn't running very well, our 33 feels quicker.
This was turbo auto too (budget doesn't stretch to a factory manual, planing to convert an auto).
Anyway, starting to think I might be better keeping the 33 sedan and modding that, as opposed to buying an R34.
Has anyone else made the switch from a R33 to a R34? Did you notice a sizeable difference between the two?
https://www.sau.com.au/forums/topic/472179-r33-to-r34-upgrade/
The r33 and 34 suspension are identical as are the auto transmissions, to be honest i couldn't see the point in upgrading (more like side stepping) from a 33 to a 34.
Ive driven both and despite the claimed extra 20kw I can't tell the difference and it's only really cosmetically that they are all that different from each other
  • Like 1
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
