HI SAUers,
I have an R33 with a GT3076R on stock manifold with external gate welded to the exhaust housing.
It was worked well but I am now upgrading the manifold to a high mount 6boost because my studs/nuts keep coming loose and I've had enough.
I need to buy a new rear housing when I upgrade manifolds because the way the gate is welded to the current one means it wont fit.
I have found a fair priced used 6boost manifold but it is a T4 twin entry (not twin scroll as it has only one gate provision?)
QUESTION:
Can I buy a T4 flanged rear housing that will fit the GT3076 in .82?
Will it give me any benefit over the T3 flanged housing?
Should I just buy a brand new T3 flanged 6Boost and get a T3 flanged housing.
Thanks all
Chris
https://www.sau.com.au/forums/topic/472194-t4-exhaust-housing-for-gt3076r-56t/
If you're completely satisfied with the GT3076 (and there's still a lot to like about that turbo on a RB25), then stay T3 high mount and be happy.
Bear in mind there's a fair bit of fab work to get the piping right and even the gate in correct position.  So it'd be good if future turbo changes allow for direct bolt in spec changes (eg move to a GT35 or something within reason).
I'd suggest you do the homework on alternative brands in the same price or performance range too.  You "might" move away from the Honeywell gear given what the cost of a bare housing is and the funds you could recoup on sale of existing gear.
Besides the higher priced options (EFR, PTE), you'd be mad not to look at BW S256/257, Masterpower/Borghetti MPR54/59, and the Kinugawa range.  There are T4 options amongst those, and the dimensions of a T4 hole may allow for a nicer transition in the collector area of a high mount.
I don't think T3 single vs T4 single will make much difference to overall performance given your current turbo is going to top out around the 300rwkW mark.  A proper split pulse setup probably will make a difference, at a cost.
Bottom line for me, you've got to price up the alternative setups and gauge what's most attractive and within your budget.  They are all going to perform differently but no dogs there.
Garrett preferred? - T3 single scroll, single gate.  Easy move to a GTX3071 or GTX3576 in future.  Don't look back.
Bigger budget? - T4 split pulse, EFR 7670 IW.
Bigger again? - T4 split pulse, EFR or PTE twin external gates.
Smaller budget? - T4 split pulse, BW S257SXE twin external gates
Smaller again and open mind? - T4 single scroll, BW S257SXE or Masterpower MPR545, single gate.
Smallest budget, still open minded? T3 single scroll, Kinugawa TDO6-25G, single gate.
  • Like 2
Thanks heaps for taking the time to reply Dale- i very much appreciate it.
I decided to keep the 3076 as it meets my needs for now.
I have ordered a brand new 6boost with a single entry T3/ ext gate and got a new T3 / V band rear housing to go with it.
I'm interested to see if it increases power/response but will be happy with just an increase in reliability and decrease in likelihood of turbo falling off the manifold!!
Cheers!!
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
