petemac Posted October 1, 2017 Share Posted October 1, 2017 Didn't even intend to buy another R32, after purchasing an ADM from Bob.... but this was too good not to bid on; One owner 12,766 km HKS muffler Tommy Kaira Recaro seats A/m HID lights, air cleaner Sports clutch A/m fog lights and 17" wheels Cusco tower bar Mbro corner lamp A/m adjustable suspension Remote / TV will come later Sideskirts a/m ? small dent (couldn't see it) Centre console has a small scratch Dash has small glue mark 1 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/ Share on other sites More sharing options...
Aussie_Delivered_R32_GTR Posted October 1, 2017 Share Posted October 1, 2017 Congratulations on the purchase........... Interesting car. How's the black car going? Any pics? Updates? Anything? It's one of the few cars I actually regret selling. Cheers...... Bob. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852365 Share on other sites More sharing options...
mlracing Posted October 1, 2017 Share Posted October 1, 2017 Wow that's a sweet score 1 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852370 Share on other sites More sharing options...
jaysevu Posted October 2, 2017 Share Posted October 2, 2017 amazing car. price range if you don't mind? haha 1 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852458 Share on other sites More sharing options...
petemac Posted October 3, 2017 Author Share Posted October 3, 2017 On 01/10/2017 at 12:54 PM, Aussie_Delivered_R32_GTR said: Any pics? Updates? Anything? It's one of the few cars I actually regret selling. Cheers...... Bob. Hi Bob, I had it in at Galvsport here, had the clutch swapped out for a standard unit, short shifter removed. Aircon is on the blink, they've already looked at it once, but still needs fixing (something with the switching/computers). They also went through all the usual things, made sure all is sweet. Also had some issues with the brake master, unfortunately made the mistake of using a local mechanic who had a reconditioned (twice) but apparently there's an issue with reconditioning those units (leaves sharp edge on sleeve) which causes it to fail again. Long story short, Galvsport replaced it with a later model unit. Haven't any photos at hand, but certainly still looks the same! See below for what the mechanic wrote re aircon. Cheers, Peter I’ve gone about as far as we can go with the GTR, I’ve got everything sorted but im struggling on the Aircon. There is an intermittent electrical gremlin somewhere between the Climate Control Module and the Fuse Box. Under some situations the signal is lost and we lose drive to the compressor. I can manually engage the compressor and get good working aircon, but I cant make it work automatically (which is no good on the road). The reason I’ve not got this totally finished, or pushed further is to primarily get in touch and let you know where we are and also my time over the next couple of weeks is soaked with preparations for our Targa event so id made sense seeing as its 2 degrees outside to work towards getting the car back to you and we can address this after the chaos dies down a bit. I have also got the misfire sorted, we had two issues causing it – One was the coil pack harness that connects the ignitor box to the coil packs, the other was the coil packs themselves producing weak spark (one normally causes the other). I’ve replaced both of these and the car drives perfectly. Obviously buying a set of coilpacks was not part of the plan, however one of the positives is your injectors initially tested perfectly so we didn’t need to clean (or charge) for any work with them. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852555 Share on other sites More sharing options...
petemac Posted October 3, 2017 Author Share Posted October 3, 2017 (edited) 20 hours ago, jaysevu said: amazing car. price range if you don't mind? haha Somewhere around the 6 figure mark.... Edited October 3, 2017 by petemac Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852556 Share on other sites More sharing options...
admS15 Posted October 3, 2017 Share Posted October 3, 2017 Re, the aircon. I had a similar issue with my r33, would run intermittently. Ended up being a bad connection on the plug for the thermistor which is a little temperature probe thats in the evaporator box under the dash. Worth a look since they cant work out what's going on. 2 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852598 Share on other sites More sharing options...
Aussie_Delivered_R32_GTR Posted October 3, 2017 Share Posted October 3, 2017 4 hours ago, petemac said: Hi Bob, I had it in at Galvsport here, had the clutch swapped out for a standard unit, short shifter removed. Aircon is on the blink, they've already looked at it once, but still needs fixing (something with the switching/computers). They also went through all the usual things, made sure all is sweet. Also had some issues with the brake master, unfortunately made the mistake of using a local mechanic who had a reconditioned (twice) but apparently there's an issue with reconditioning those units (leaves sharp edge on sleeve) which causes it to fail again. Long story short, Galvsport replaced it with a later model unit. Haven't any photos at hand, but certainly still looks the same! See below for what the mechanic wrote re aircon. Cheers, Peter Hi Pete, nice to hear from you..... The clutch and shifter I get, I too would have changed those had I kept the car. The other items surprise me as all was working well when I sold it to you. Admittedly, that was a few years ago now. How long after buying the car did the air-conditioning and master cylinder play up? Ta...... Bob. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852604 Share on other sites More sharing options...
petemac Posted October 3, 2017 Author Share Posted October 3, 2017 Hmm, probably 12 or 18 months.... Just normal wear and tear I guess for vehicle of that age. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852606 Share on other sites More sharing options...
Aussie_Delivered_R32_GTR Posted October 3, 2017 Share Posted October 3, 2017 2 minutes ago, petemac said: Hmm, probably 12 or 18 months.... Just normal wear and tear I guess for vehicle of that age. Oh ok..... As long as it wasn't 5 minutes later! I'd be happy to buy it back at your purchase price, plus all repair costs, transport costs plus 3% interest compounding per year you have had it, plus your rego fees plus freight back to Sydney.......... Deal? Bob. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852607 Share on other sites More sharing options...
petemac Posted October 3, 2017 Author Share Posted October 3, 2017 hahaha, Every time I take it for a drive, I think to myself, Bob must be kicking himself!! Must kindly refuse your offer! Cheers! Pete Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852608 Share on other sites More sharing options...
Aussie_Delivered_R32_GTR Posted October 3, 2017 Share Posted October 3, 2017 Fair enough......... Yep ..... Win some and you lose some. All about timing eh! Here are some memory photos. Cheers.... Bob. 1 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852610 Share on other sites More sharing options...
petemac Posted October 4, 2017 Author Share Posted October 4, 2017 Thanks Bob! Still the same now - though looks better with the slimline NSW plates! I'll try and take a few shots and upload on the weekend. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7852760 Share on other sites More sharing options...
JayJaysIsf Posted October 8, 2017 Share Posted October 8, 2017 Hi Pete mate congratulations on the tommy purchase, great car and already a collectors item 1 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7853472 Share on other sites More sharing options...
petemac Posted October 14, 2017 Author Share Posted October 14, 2017 For those interested, with the Tommy, was happy to get confirmation on the original service records....Quoting below my agent Geoff from Prestige Motorsports (highly recommended). You have records starting in 1994 (13 Dec 1994 at 6 months old and 569km), then 14 June 1995 at 1,950km, 16 June 1996 at 5,905 km, 24 May 1997 at 7,355 km, 21 July 1999 at 9,040 km, 26 July 2001 at 9,908 km, 28 July 2003 at 10,907 km, 28 Aug 2005 at 11,546 km, 2 Oct 2015 at 11,839 km. So in that 10 years it travelled less than 300 km and didn’t go back to Nissan for any more servicing, just kept in a garage and you can imagine all sorts of situations that may have led to the diminished use then the car finally being sold – perhaps something happened to the owner or their circumstances changed. The latest inspection was done in October 2015 at 11,839 km and the following items were replaced: Engine oil Oil filter LLC Brake fluid Drain washer Radiator drain cock Radiator hose (2) V belts (3) Fuel tank Fuel pump Fuel filter Fuel gauge unit Fuel hose (7) Fuel additive Front suspension upper link (2) Front wiper refill (2) Rear wiper blade Bob, Just took the ADM out for a quick spin - have to excuse, car is filthy. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7854338 Share on other sites More sharing options...
petemac Posted October 14, 2017 Author Share Posted October 14, 2017 Got some pic's of the spares included - wrapped to have the original airbox and wiper unit; Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7854343 Share on other sites More sharing options...
Aussie_Delivered_R32_GTR Posted October 14, 2017 Share Posted October 14, 2017 Well done!!!!!!! Good to see it went to a respectful owner...... I'm just about to leave as my AH3 ADM is participating in a Pride of Ownership Day today. This is a pic of her after a quick wash yesterday.. Cheers, Bob. 1 Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7854356 Share on other sites More sharing options...
Birds Posted October 14, 2017 Share Posted October 14, 2017 Wow Geoff has been in the game a long time. I remember looking at getting a car through him 13-14 years ago I think it was a flat rate fee for their services too, like $1000. Link to comment https://www.sau.com.au/forums/topic/472215-new-purchase-r32-tommykaira-45b/#findComment-7854360 Share on other sites More sharing options...
