Hey SAU!! Was installing my wheels on my Ecr33 Skyline over the weekend and noticed a small play in my upper kingpin. Unfortunately I dont seem to have the proper terminology or part name to find anything on google. Il include a picture to make sure we are referring to the same part. If someone could put me on the right track it would be greatly appreciated!
https://www.sau.com.au/forums/topic/472224-part-name-id/
11 minutes ago, hardsteppa said:
Pretty easy to replace if you have a press, but you might just need to tighten the nut. Pull the cap off and have a check.
Already did!! Tight as F&*=$ so im guessing its the inside bearings. I have a press handy so its going to be a easy bearing swap once I source all the bits and pieces as it seems there is a few other parts to change from what i can see of a part breakdown I just found online!
https://www.sau.com.au/forums/topic/472224-part-name-id/#findComment-7852577
