Bought this external oil pump kit to use in my 26/30 build, but my engine builder believes it will be overkill for my street driven application at the expense of my air conditioning, so I've decided to stick with an upgraded internal pump instead.
This kit allows you to ditch the notorious internal oil pump setup and take those failure prone components out of the equation. For those who don't have a spare 10k to dump on dry sump, this is the next best thing to insure your expensive engine build or high revving race engine that will see more action than mine.
Everything is in new/unused condition - I believe the previous owner had it test fitted to their engine before they decided to part out their project, so there are handling/tool marks on the parts, but they otherwise look great.
My kit includes:
- Ross Tuffbond Race Balancer (306510, rated to 1000hp), with 20% and 7% underdrive pulleys (protects your water and P/S pumps at high RPM), gilmer belt drive and belt guard washer
- Moroso Single Stage External Pump w/ gilmer drive
- Bracket for pump mounting (replaces your air con compressor)
- Gilmer belt
- Hoses/lines with AN fittings
What you see is what you get. Only thing I don't have is bolts for the bracket. You'll also need to tap your sump to run a line to the pump.
From my googling, the balancer is RB30 fitment - you MAY be able to use this on an RB26, but please do your own research - I'm unfamiliar with crank/ancillary similarities. Likewise, I believe the AC bracket is designed for an RB30 - I don't know if the AC mounts differ on RB26.
How it will look setup (different parts but much the same deal)
To buy a similar kit brand new, you're looking at around 3k from Ross Performance:
https://rossperformanceparts.com/product/nissan-rb-wet-sump-kit-single-stage-2/
I'm looking for $1800ono - same cost as a Tomei internal pump. I may be willing to separate the pump/bracket/belt/hoses as I can still use the balancer in my build.
Located western suburbs Melbourne. Happy to post at buyer's expense.
:cheers:
https://www.sau.com.au/forums/topic/472242-external-oil-pump-kit-rb26rb30/
  • 4 months later...
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
