What is the power range you want, and your setup etc?  It's hard for anyone to tell you which is better suited when you've mentioned two turbos which flow different to each other.  I'm personally not a huge fan of either in the current market, much better options for what both can do out there now.
The power range id like, would be around 350kw and at the moment the upgrades are, 750cc injectors, link G4 ecu, front facing plenum, 6 boost manifold and so forth, if there is a better turbo that is more suited for the type of set up I’m after, which would be more street but occasionally track.
Edited by Fr3akyR33
Ah that makes life simpler.  On 98 octane?   I can say straight out, a GT4088R is overkill for that power... though these days a GT4088R is pretty much pointless in every way unless you are pretty much given it.
Edited by Lithium
  • Like 2
For simplicity go internal.
External means you'll need a new manifold, dump pipe, wastegate, plumbing so on and so forth.  To go drive in drive out with a new external gated turbo you're probably talking $6k including turbo.  To do it internal you're looking at half that including turbo. (That's JUST to buy the turbo and have it fitted - NOTHING ELSE)
Note, you're going to need a hell of a lot more than just a turbo to hit your power goal.
350kw is going to be a $10k-$15k spend.
Turbo
Cooler
Injectors
ECU
Exhaust
Coilpacks
Clutch
AFM
Filter
Fuel pump
Fitting parts
Tuning
I suggest you stop worrying about specifics, ie. which turbo, and spend the next 6 months reading and researching these forums as to what you're getting yourself into.  It's clear you have absolutely no idea so you need to research like a madman.
Start researching for a well regarded workshop near you who you will get to do the actual work and then work with them, as well as what you can learn here, and start buying all the pieces you'll need to complete the jigsaw (after lots of research).  If you rush into it and start hanging all sorts of random shit off your engine, you'll end up spending $25k and you'll get a shit outcome.  Research, patience and knowledge is your friend.
Seriously for what you want just shove a gtx3071, a good exhaust and intake, a good cooler, a fuel system to feed and an ecu to control it and a clutch to hold it
and if it's a 33 engine save some money for a bottom end cause it'll hurt a rod eventually
  • Like 1
  • Thanks 1
If it is purely for street use and not used in a competitive motorsports environment, then 300kW is plenty for a car with basic suspension modifications (i.e. a set of coilovers) and the factory LSD.
270~300kW is very achievable with a small budget and will be "fast" enough and "fun" enough.
Once you start go to beyond that, expenditure increases exponentially where as before that it is linear some what lol.
Hypergear ATRG3SAT would easily do that on 98RON and give you a bit of headroom in future if you ever decide to spray some WMI or go E85.
Another question before you start throwing out turbo makes/models etc. is when you want the turbo to come? yes any big turbo can "make" the numbers you want but when is another question?
No point slapping a biggish turbo on your car to make only 300kW and have it come on late - very american mentality. "oh be dayem, it makes 500hp on a mustang dyno, and I dont' mind the lag because I'm american"
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
