Garrett GT4088 Vs GTW3476
Fr3akyR33
 Share
1 hour ago, Dose Pipe Sutututu said:
You're better off with a Hypergear turbo to be honest.
His latest high flow will get you close to 300kW on 98RON in the stock location, stock dump, etc. (Just need the right supporting mods).
On E85 or WMI you'll easily go 350kW+
Is there a reason you push hypergear so much over other brands? I notice it's not just in this thread but plenty of others as well
In context there are probably not many current alternatives which bolt on so easily and perform fairly well - though as soon as you go to custom piping etc I think you're better off looking at the likes of Garrett etc.
  • Like 2
Best reason I can think of.  They are a bit cheaper but they are also relatively laggy for the power they make compared to more popular/big name options - in my experience
Edited by Lithium
I’m open to opinions and reviews on turbos that you guys have had in the past.
Ive had a look at garret, precision, kinugawa, hypergear, done research on all and it’s between hypergear and garret probably! Still learning as we discuss anyways.
It's because it's a complete bolt on solution, yes a GTX3071 "might" be bolt on, but you still need a new intake new water/oil lines and by the time you're done that's nearly double the price of a Hypergear.
Most GTS-t owners:
  • are on a budget
  • usually do the work themselves because of point 1
  • want power fast
  • want not so much lag
  • want plug and play
If someone had a built motor, and wanted 400kW+ etc. said they wanted power/response for roll racing/track work then I wouldn't recommend a Hypergear. There are other threads where I've mentioned GTX3576s or EFR8374s, etc.
Just to be clear, I am not sponsored by Hypergear nor is there any financial benefit for me in recommending the brand.
I met a guy having trouble with an rb30 chewing through gt3582r turbos with .63 rear.
What ended up happening was rear of chra turned blue and cooked the bearings.
They only lasted a few thousand kms.
Put a Borg Warner airwerks on with bigger rear and the car fell apart around the turbo.
I'd imagine a .82 on 3576 would work much better.
  • Like 2
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
